MiddleEarthGeek
Hi,
Building the following new rig:
Thermaltake Black "Shark" case
Thermaltake Big Water Liquid cooling kit
AMD Athlon 64 3500+ 90nm process Cpu
ASUS A8V Deluxe mobo
ATI Radeon 9600XT Pro 128mb Video Card
Crucial Ballistix pc3200 DDR ram 2Gb (4 512k sticks)
Plextor 716a DVD-RW/CD-RW Dual Layer Drive
Seagate 300GB 7200 rpm HD
UV Blue Round IDE Cables
2 Cold Cathode UV tubes
Logitec MX1000 Laser Mouse
Logistix Blue LED illuminated KB with Cell Phone alert
Samsung 213T 21.5" 25ms LCD Flat Panel
I received the mobo, don't have the Bigwater yet, but I'm concerned since when I removed the Heatsink retainer, I THOUGHT there should be 4 holes in which to mount the block clip, but there are none. Additionally, the metal plate (reinforcing plate) on the back of the MOBO is REALLY stuck on.....taking the screws out do not allow it's removal....I'd have to have the holes and remove the plate to do the Big Water, right? Is it even possible to use the Big Water with this mobo? I looked all over Thermaltake's site for MOBO compatibility but found none...I just assumed all socket 939 mobos were drilled for the holes I need. IF I can't use the mobo, what would be a good choice, given the rig in question and the desire to liquid cool using the Big water?
I'm an enthusiastic 1st time builder......(first time in a long time, that is)
MEG
MEG
