Thermaltake Armor, removing led lights
xxceler8
80
I like this case, but I like my room dark so I don't like bright led lights. It is possible to remove the LED lights associated with this case, without effecting the fans, etc?
Zepper
18,998
If you mean the red LEDs in the fan(s), yes. just cut the leads to the LEDs. You'll want to make sure the cut leads can't wander by tacking the cut ends down with some glue or clear tape. Though if it is possible you may sell the case in the future, then your buyer may want the LEDs. So it might be a better idea just to replace the LED fans with some better, plain black ones and store the LED fans away for that time.
.bh.
