imported_Ged
Problem: the graphics card area gets really hot. So much that the case door gets warm.
Idle GPU temp is 58C load temp is about 82-84C.
The 120mm intake fan in the front of the case doesn't seem to move air in this area of the case enough.
Looking for a fan kit or bracket that will let me put a fan in such a way that it will blow air across or over the graphics cards and move the hot air from this area of the case.
I tried a PcToy (Zalman) fan Bracket, but that won't work. Just doesn't fit right and would end up touching the RAM sink on the front side of the graphics card in PCIE slot 1.
Other thing I was thinking of was cutting a hole in the case and putting a fan that blows cool air directly over the area.
I'd like a kit if possible or a new case door with a fan hole in it. Any thing out there to address this problem?
