Thermaltake A1745 Extreme Volcano 12 CPU Cooler
Smokin Gunn
1,184
www.gunnsdeals.net
Link :D
This is one loud puppy @ full load, but it sure cools great!
Application for AMD Athlon XP up to 3400+
The best cooling, high density all copper heat sink (66 fins)
Powerful 80x80x32 fan, 2 ball bearing,triple blades
VR control function, fits in 3.5hard drive bay and PCI slot
Auto temperature control
All copper base
P/N
A1745
Fan Speed
2000 RPM at 20°C ~
5500 RPM at 55°C
Fan Dimension
80x80x32 mm
Max Air Flow
26.50 CFM at 20°C
72.92 CFM at 55°C
Heatsink Dimension
82x65.6x49 mm (66 fins)
Air Pressure
3.29mmH2O at 20°C
9.06mmH2O at 55°C
Rated Voltage
12V
Noise
21 dBA at 2000 RPM
48 dBA at 5500 RPM
Started Voltage
7V
Bearing Type
2 Ball bearing
Rated Current
0.08 ~ 0.45A
Life Expectation
80,000 hours
Power Input
0.96 ~ 5.40W
Connector
4 PIN
Weight
708g
