Hello,
Since i cannot get a straight answer out of Thermalright themselves regarding an issue i have stumbled across with my XP-120, i thought i would try here for the first time. I have tried and tried to solve this problem but it keeps throwing it back at me no matter what i try, im very frustrated having spent about £40.00 for this Heatsink and it won't even work properly.
I used the Retention Mechanism i got with the XP-120 as well as a Metal Backplate (which i needed) for my Gigabyte Motherboard, seeing as GB ship the 939's with Plastic Backplates. Everything goes well, i then apply a very thin layer (thin enough to see the Metal underneath slightly) of Arctic Silver 5 on my CPU and Heatsink Base. I then mount the XP-120 onto the CPU by the looks of it, it makes very good contact with my Processor. I then put my Panaflo 120mm Fan onto the XP-120 and plug the 3pin plug into the CPU Fan Header. No problems so far.
Once i put all the components into the case and plug them in this is where i get the problems. First of all the PC Switches on, i get a motherboard light and everything spins and whirs like normal. However, im getting no Post Screen just a blank screen no beep no boot nothing. At this point i thought it was my GFX Card so i slapped it into my 2nd PC no problems with my GFX Card thankgoodness. I started fiddling around with things like the Heatsink and the fan ontop of it. Eventually, after 5 tries, the PC Booted and i thought it fixed itself ... until i went into the BIOS to check my CPU Temperature of course.
The CPU Temperature was reading out at a whopping 110C it then dropped to 104C and finally crashed, i.e shut itself down to prevent damage. I was extremely worried why i was getting such a high reading in less than 20 seconds of computer switch on. The Heatsink was not even warm to the touch, even at the bottom near the CPU so how was i hitting 100C+? Anyway, i fiddled with the XP-120 some more and instead of plugging the fan into the CPU Header i plugged into a normal System Fan Header. I Switched on, it booted first time. Went into PC Health Status in the BIOS and the CPU Temperature was at 34C ... i was beginning to think i had solved the issue after 3 days of failing. I also set the Alarm Temperature at 80C just to make sure.
So i went on with my business, got into XP and started to surf the internet for a CPU Heat Monitor of some description. I got one called HMonitor (http://www.hmonitor.net/). I installed it and looked at my CPU Temp, it was normal at about 35C i was extremely happy. So i decided to leave the PC and make myself some dinner, when i returned the Monitor was reading out at a whopping 108C but yet there was no Alarm from the PC saying the CPU had surpassed 80C which it was set at. So i turned the PC off and turned it back on, it booted ... i went into BIOS and it was reading at 110C but still no Alarm from my PC. At this point i was annoyed so i switched off the PC and went out for 4 hours with my friend.
I returned home and tried to switch on my PC ... i am back to square one again. No beep, no post and no boot just a black screen. I did get it to boot once and it was still reading the CPU Temp at a whopping 110C i turned off and now i cannot turn it back on again. The frustration at this point started to set in so i gave my PC case a good kick and decided to seek help. Thermalright are just useless they say it's the Fan which it cannot be as they recommend this fan or the Thermal Paste it applied to thick. Again, which is completely false as it's so thin you can see the CPU Spreader and the Heatsink Metal bases.
Can anyone help? Has anyone encoutered this issue with an XP-120? I have searched all over the Internet and i cannot find anything. I hope someone can shed some light on this time of darkness for me! Thank you for your time.
P.S - If i use my Stock AMD Cooler everything works fine and dandy, the CPU Temperature in BIOS reads at 41C and i can play games etc with no overheating.
PC Specifications:
Gigabyte K8NSNXP-939 nForce 3 Socket 939 Motherboard;
AMD Athlon64 3500+ Winchester Core;
2.0GB Corsair TwinX Platinum Series PC4400 Memory;
256MB nVidia Galaxy GeForce 6800GT @ 415/1.11;
2x 74GB Western Digial Raptor Hard Disk Drives on Raid 0;
Soundblaster Audigy 2 ZS Soundcard;
420w Black Tagan Dual Fan Power Supply;
Windows XP Professional with Service Pack 2.
PC Specifications:
