Thermalright Ultra-120 Extreme
lou61166
23
Hi all, i have a antec 900 case with a asus P5E mobo,will the Thermalright Ultra-120 Extreme fit.or should i go with something else that is just as good.
DerwenArtos12
4,278
There should be no problems but, the easiest way to figure out if the TRU120E is right for you is to ask if you know what lapping is. If the answer is no, then get the Tuniq Tower. If the answer is yes then go for it.
PCTC2
3,892
33
It will have problems with fitting with a side fan installed with front to back airflow. Bottom to top airflow has no problem with a side fan.
lou61166
23
Thanks for the advice,the site i am going to buy it from will lap it for me,but once they do that it will void all warranty and i will not be able to return it.
DerwenArtos12
4,278
If you're comfortable with that then I say go for it, it is essentially the best out when lapped.
