WoodButcher
Originally posted by: Old Hippie
Are we to the "add an air conditioner" part yet? :laugh:
No, but if he got the enzo on the NB and turned the TR to face the back fan we could close this case!
Originally posted by: Westside
I have a q6600... my temprature has been around 44 Celsius around each core... when I open my PC case, the temperature drops to around 36. I was wondering if this is a problem with the airflow of my case.
Hmm... Using too much thermal paste is actually bad for the temperature?
and the location of the pins also, they are straight out at the corners so it may sit kitty-corner or a little diagonal on the chip. Not a problem.Multiple push pin locations for universal mounting on various board
assembly. (hole to hole distance 54.6mm and 59m).
Cool! I remounted this guy with todays temprature around 23 degrees, I am getting core tempratures areound 27 to 32 celsius per core. However, installing and reinstalling this guy was the worst nightmare. I swore like a sailor when I installed it.
Originally posted by: WestsideWhy did they make a great cooler and messed up on both the fact that it has a horribly unflat base and difficult installation process?
My god, my ambient today is around 37 and my CPU is around 44 again... Time to get some water coolers... The only reason I don't want to is because it is an absolute pain in the behind. I must flip a coin to decide wisely.
Originally posted by: zagood
You're better off spending the money that you'd drop on decent water cooling for an air conditioner instead. Lower your ambient, lower your CPU temp. Easy as pie.
mmmmmmmmmm pie.
-z
Originally posted by: aigomorla
LOL... apple or cherry?
