ZzZGuy
Lame pun aside, I'll be getting the Thermalright ULTRA-120 Extreme CPU heat sink mainly because you pick which fan to use, and how many. It also gets good reviews for cooling and I will only be doing moderate OCing.
http://www.ncix.com/products/i...nufacture=THERMALRIGHT
I'll be using either a Slip Stream or Noctua 120mm fan depending on what I can order from my local computer store (Noctua being better IMHO). The two big questions I have is what RPM and should I use just one fan or two fan for a push/pull airflow setup.
I use the two reviews from Silent PC Review (SPCR).
http://www.silentpcreview.com/...e695-page4.html#noctua
http://www.silentpcreview.com/article832-page1.html
Also note that I am assuming that two fans at a low RPM pushing almost as much as one of the same fan at full RPM between the two will make more noise then the single fan at full RPM, based on the noctua review I posted.
Would one fan do the job just fine or will the push/pull setup create enough extra airflow inside the heat sink that it would be worth the extra noise?
Would it even be worth it to have the push/pull fans at full/same RPM as a single one.
My current opinion is to try a single 1,200 RPM fan and add a second one if it isn't enough. If proven that the two fans are useless then replace with a 1,600/1,900 RPM version.
One last note, I'm really only concerned how quiet the fans are at idle unless the noise is so excessive I can hear it over my headphones or others can hear the PC through the walls..
