Originally posted by: RalfHutter
Any of them should work fine. Flip a coin.
I'd probably go with the Zalman because you wouldn't even have to think about what fan to put on it.
Can you even replace the fan on the Zalman? It's not in an enclosure, and I didn't know if you had to do anything special if the fan should ever die.
how do you do that with three choices? 🙂
Originally posted by: Nickel020
Since you are considering the SP-94, price does not seem to be an issue. Therefore, if it works on your mainboard, get a Thermalright XP-120. Best heatsink out there. If you decide to get the Zalman, get the AlCu version. It has been proven time and again that the CU and the AlCu have the same performance and the AlCu is cheaper and lighter.
