I bought this followed the directions and then wondered is it better to have the fan blowing away or on the heatsink? The directions I got are calling for it to blow away from the heatsink.
i have mine blowing not sucking, and if i remeber correctly, my temps dropped about 1-2 degrees on average. try either way and go with what works best.
the SK-6 was designed to have air pushed through the fins, so you would want it blowing. It is highly doubtful that reversing the fan direction would bring lower temperatures.
