- Jan 23, 2005
- 15
- 0
- 0
I am going to fit a Thermalright XP-120 heatsink on my new motherboard, which in case you didn't know, is an absolutely massive heatsink.
When I fit the heatsink in one way, it comes in contact with DDR DIMM 1, and the other way it gently comes in contact with some capacitors.
I don't want the memory damaged, so I don't want it facing the way which will interfere with the Memory Modules, and I have learnt that heat will significantly diminish the lifespan of a capacitor over time, even ones rated for 105*C, and it will especially diminish the lifespan when some of the heatpipes are touching it, which they are.
I was wondering, if such a product exists for Thermal Insulation(Maybe in a stickytape). Obviously it mustn't be conductive of heat or electricity, and it will need to fit between a capacitor/heatpipe(the heatpipe is part of the XP-120 heatsink) and make it so that none of the heat on the heatpipe transfers to the capacitor (or have minimal heat transfer).
If anyone knows of such a product, even if it isn't designed for PCs, but would work anyway. Or has any other advice on this problem, please help me.
Thanks!
Thanks!
