- Nov 9, 2000
- 20,127
- 6
- 81
I believe that the KT333 motherboards use the AthlonXP internal diodes to measure CPU temp. Does that reading normally read higher than the thermistors earlier motherboards use? My CPU is an AthlonXP 1900+ and my motherboard is an Epox EP-8K3A+. I am using a Taisol CGK760002 hsf with good silver thermal compound and 2 80mm rear exhausting case fans. My case temp. averages about 30C and the cpu is ranging from 45C to 48C idle and pegged out at 52C running Prime95. When I was using this CPU with a Cooler Master CB5-6G52 hsf on an MSI K7T266 Pro2-RU (KT266A with thermistor under the CPU) the case temp. was about the same but the idle CPU temp. was about 40C to 42C and pegged out also at 52C using Prime95. Thanks for any ideas you might have on this.
PS - the Taisol is quieter than the Cooler Master so I am willing to suffer with a warmer chip if the cooler is at fault for the higher temp. and not the temp. measurement instrumentation.
