Thermal Cooling Venting
foodfightr
1,563
Do you think I would be able to mount this on a Thermaltake Big Typhoon to the case fan on the door of my case? I would love to be able to push that heat straight out of the case.
http://www.casecooler.com/casecooler/loblthcoveki.html
Anyone know of a different brand that makes this? Logisys only makes 80mm and I'm trying not to use an adapter if I don't have to.
Zepper
18,998
Those are mainly useful for bringing outside air directly to the CPU for cooling with a fan at both ends both blowing toward the heatsink. They are not particularly useful in exhaust mode. The description in the link is not particularly apt.
.bh.
zagood
4,102
You COULD do it, but you'll still need another fan for intake air to your case to help cool the other components. Those ducts are the most useful if you have a fan mounted to the side panel or one in the top part of your front panel.
-z
foodfightr
1,563
.bh.
This thermal Cooling Venting kit is and economical and effective way to cool your PC because it simply takes out the hot air directly out of the computer.
Anyways, does anyone know where I can find something in the 120mm size?
Ping to the Pong
217
just go to your local hardware store and look around. But based on your setup, you will have to what zepper recommends and have the the fan positioned where it will grab colder air and direct it to the heatsink.
