there's more precision in fahreinheit, why do others keep using celsius?
sdifox
100,481
17,952
The frustration that I have to deal with daily is that all architectural drawings are in scale metrics, mechanical specs can be 1/2 in metric and 1/2 in imperial specially volume, pressure, and flow rate.
It is a pain in the arse that I have to constantly convert from one system to another, and then have all machine made in the US with specs in what ever imperial scales that the manufacture feels like printing it in. Then there are curve balls that I have to deal with is that some machines that are from the EU that are in metric that have to be mate into the rest of the system that are in imperial.
Not only that I have to deal with machine that have different voltage & HZ rate, I have to deal with flow/pressure/temperature all in different measurement. Sometime it is such a cluster fuck that I have to take a day to clear my mind so that I don't make mistake with conversions.
<--- plumbing/gas/HVAC mech, specialize in geothermal
lol, as long as it's not space mission, you are fine :biggrin:
It is a cluste rfuck to have to to deal with 2 units.
13,822
Celcius makes more sense. 0 for freezing point, 100 for boiling point, of water which is the universal liquid. Nice easy to remember numbers.
I also prefer metric for physical measurements as it is more accurate, and easier to deal with when using a program like autocad. 1.5 units can be 1.5 metres which is 150cm, etc... when you get into feet and inches then you have to deal with fractions and crap.
dainthomas
14,936
3,915
F is retarted and it should be not used.
Why?
What does the 0 and 100 represent in Fahrenheit?
Answer: Some random bullshit: Praise the lord, Darwin is wrong, Universe is 6000 years old.
What does the 0 and 100 represent in C?
Answer: Freezing and Boiling Point of Water, the most common substance in our world (our body is 70% water). Water in turn is composed out of the most common substance in the Universe which is hydrogen.
C wins. Only stupid US rednecks use F.
0 F is the freezing point of salt water. Which is actually what our body contains. 0 C is the freezing point of fresh water. And knowing the boiling temperature of water is fairly useless for 99% of people. You turn on the stove and leave it on until the water boils.
F wins. Only effete Euro-trash and communists use C.
yhelothar
18,409
39
meh,
fahreinheit for weather and body temp
celcius for everything else
double win.
Although I'd prefer growing up with just celcius.
Parasitic
4,000
Kelvin is the only system that actually makes sense. I prefer C because it's just Kelvin with a reasonable offset (no scaling factor) to make every day use easier.
(yeah I know C came first but I like to think of it like this)
You can use the Rankine scale to define temperature too. It's the absolute version of Fahrenheit.
iGas
6,240
Epic Fail!
Sea Moose
6,933
7
0C = water freeze
100 = water boil
1 cubic meter water = 1000 Litter of water = 1000 Kilograms
1 Metric tonne = 1000 Kilograms
1 Kilometer = 1000 Meters = 1,000,000 Millimeters
1 Joule = 1 Newton = 1 Watts/Second
1 Kilowatt = 1000 Watts
1 Kilopascal = 1000 pascal = 1 Kilonewton/square meter
32F = water freeze
212F = water boil
1 cubic foot water = 7.48051945 gallons = 62.42796 pounds = 998.84736 ounces
1 mile = 1760 yards = 5280 feet = 63360 inches
[SIZE=-1]1 ton = 20 [/SIZE][SIZE=-1]hundredweights = [/SIZE][SIZE=-1]80 quarters = [/SIZE]160 stones = 2240 pounds = 35840 ounces
1 acre = 4 roods = 160 poles = 4840 square yards = 43560 square feet = 6272640 square inches
Can you see how retarded the imperial system is, and I'm not going to bother with BTU, candle power, horses, PSI, etc...
PS. You are a dinosaur that will soon extinct because the world move on to something that is easier to use thus minimizes calculation error.
I was born in the Metric system, but living here in Canada we are force to use the retarded imperial system because the stupid/old American cant learn new tricks.
we have a winner. Now who out there is stubborn enough to argue against igas's winning point?
dullard
26,066
4,712
you win.
for presenting a clear solution, but more importantly for understanding the point of the thread.
everyone else is too busy trying to explain that decimals can be used in Celsius to increase precision, because apparently they are that much smarter than i am.
i had no idea that you can use decimals with C until they schooled me.
He wins, except for the fact that he was wrong. That study has been done. 1°F is the typical limit that people can feel.
QueBert
22,982
1,179
C sucks, and UFC in was in England, they suck with that Stone shit they use. Who the fuck weighs themselves based off that? I weigh 14.2857 Stone according to the converter I found, that's the gayest shit ever.
F for life, knowing the freezing or boiling temp of water is utterly useless. When I need to boil water I put in on the stove until it bubbles, you can't burn water so it doesn't matter. As for freezing I put it in the freezer until it's... frozen! What novel concepts.
Cattlegod
8,687
Celsius is NEAR 0 for freezing water (even in ideal lab conditions, it isn't exactly 0°C), and is rarely at 100 for boiling water (it is often several degress off due to air pressure variations). And the temperature for both depends a lot on the number of nucleation points available (water will stay liquid far below 0°C if there are no nucleation points). Plus using water for your calibration is arbitrary anyways. Why not ethanol or any other common chemical?
Fahrenheit at least has the advantages of:
1: being weather related (most of the world is between 0°F and 100°F and extremes on either side of that range are a health hazzard).
2: being nicely tuned to heath. A temperature above 100°F is a fever. Why would you want to memorize 38°C when 100°F is easier? Note: using human health is just as arbitrary as using water.
3: matching the precision of human feeling. We can tell the difference between temperatures that are roughly 1°F apart. A 1°F change in the outside temperature or the thermostat is just enough to notice. Like the OP said, 1°C is just too coarse of a temperature range and you are forced to go with decimals.
But, in the end both suck. Neither have an absolute zero at 0. Rankine is the best of all worlds. A true zero and temperature intervals that match human touch.
right on
Parasitic
4,000
Seriously, why the fuck do you guys feel so strongly about having to convert America to a SI nation?
If people feel like using Fahrenheit, lbs, and miles in their everyday life, let them. In sciences, medicine and engineering, most of the labs have already switched to fully metric systems. Don't tell me that this isn't enough. People still partially use imperial units in some parts of England, Canada, Hong Kong, etc. Petroleum is still sold in terms of gallons in a lot of countries.
In addition, the cost of conversion is prohibitive. It costs NASA an additional USD$370M to retool and use the metric systems to manufacture and engineer their space project. Think about how much it would cost in the rest of the country.
http://money.cnn.com/magazines/fortune/global500/2009/full_list/
Here's a list of the top 20 corporate entities in the world:
Royal Dutch Shell
Exxon Mobil
Walmart
BP
Chevron
Total
ConoccoPhilips
ING Group
Sinopec
Toyota Motors
Japan Post Holdings
General Electric
China National Petroleum
Volkswagen
State Grid
DexiaGroup
ENI
General Motors
Ford Motors
Allianz
From the list above, if we looked at only engineering (incl. petroleum) companies, we would have the following list:
Royal Dutch Shell
ExxonMobil
BP
Chevron
Total
ConoccoPhilips
Sinopec
Toyota
GE
Volkswagen
State Grid
ENI
GM
Ford
Out of those, let's just count the companies that do direct business with the US:
Royal Dutch Shell (458)
ExxonMobil (443)
BP (367)
Chevron (263)
ConoccoPhilips (231)
Toyota (204)
GE (183)
Volkswagen (167)
GM (149)
Ford (146)
(number) indicates gross revenues in billions of USD. All of those sum up to be ~2600 billion USD.
Let's say that it will cost 5&#37; of overall revenue to retool all of their existing imperial units systems to SI. Note that for NASA, whose operating budget is USD $17B, the retooling cost of one project is USD$370M, it works out to be roughly ~2%; so an overall 5% estimate should be reasonable for the entire organization and let's say it will be for all companies.
5% of USD$ 2600B is USD$130B. For comparison, this is about as much as 89% of Ford's gross revenue last year, 9% of Canada's nominal GDP, 14% of Australia's nominal GDP, 100% of New Zealand's nominal GDP, and 3 times the NET profit of ExxonMobil.
Now, I'm sure if somebody wants to foot the bills of retooling, America will happily oblige. Until then, people from other countries whose economy and welfare enjoy the benefits of R&D and engineering done by American firms should probably let it go.
Jeff7
41,596
20
Then I'd like to see a study that shows how much time is wasted, and how many things are botched, based on the time spent on converting (or forgetting to to so) from one unit system to another.
One-time cost of conversion vs year after year after year of the adverse effects of performing conversions.
In this case, retooling would also be called "short term costs for long term gains," something the US tends to do poorly.
Sounds like a perfect argument for Celsius, with its "larger" degrees.;)
Your degrees would seem to cover a very large, vague range:
0: Damn cold.
1: Less cold. Good for beer.
2: Comfortable
3: Hot
4: Boil
5: Fire
Outside right now, it is currently 1&#176;Q.
Born2bwire
9,840
Honestly, metric is completely arbitrary. There is absolutely no rhyme or reason to how they set the units.
A meter is distance travelled by light in 1/299792458 seconds? Sure ok, what ever.
A kilogram is the mass of a volume of water of the distance travelled by light in 1/299792458 seconds cubed? If you say so Frenchie.
100 grad is the boiling point of water? Yeah, I know exactly how hot that feels. :rolleyes:
The English system is the only system that actually makes any real world sense.
0 is the freezing point of salt water, like in our bodies.
100 is the internal temperature of the human body and boy that's not a hard thing to find in a pinch is it?
1 foot is the length of the average human foot, I think most people have one of those.
1 yard is three feet. Even beauty contest entrants can count to three.
1 mile is 1000 paces. You can walk and count at the same time can't you?
1 pound is 7000 pieces of grain, the true standard of the average farmer.
1 acre is the area plowed by a typical farmer and ox in a day.
These are the units of the people, something that the average person can relate to, not set by some high-faluting pie-in-the-sky Gaullic scientist who wouldn't know the first thing about living in the real world. And you know, for all their little mathematical knowledge and calculating machines, they sure whine a lot about having to divide by something as simple as three or four. Yeah, now who looks dumb, eh?
Colt45
19,720
ExxonMobil (443)
BP (367)
Chevron (263)
Toyota (204)
GE (183)
Volkswagen (167)
GM (149)
Ford (146)
Let's say that it will cost 5% of overall revenue to retool all of their existing imperial units systems to SI. Note that for NASA, whose operating budget is USD $17B, the retooling cost of one project is USD$370M, it works out to be roughly ~2%; so an overall 5% estimate should be reasonable for the entire organization and let's say it will be for all companies.
I'm not sure WTF you're getting at there.
VW is hard metric. I'd assume Toyota is too. Ford and GM are half and half, hardware at least. Not sure at the drafting stage.
No Idea what the oil Co's use, I would assume that depends on the specific installation, being global outfits.
Royal Dutch Shell (458) .........NL
ExxonMobil (443)
BP (367).................................UK
Chevron (263)
Toyota (204)..........................JP
GE (183)
Volkswagen (167)..................DE
GM (149)
Ford (146)
Say what again?
