When I want to cut out fragments of movies without re-encoding in W LosslessCut 3.59.1, for some movie formats
File information
there is no audio preview
File not natively supported. The preview may have no or low quality audio, but the exported file will have lossless audio. I can convert the file in the menu for preview with better sound quality.
When I updated the LosslessCut program to version 3.61.0 Pre-release, sound appeared in the preview, but when playing some video formats in this program, such as this format, the image still becomes blurry.
When in this LosslessCut program, regardless of whether version 3.59.1 or version 3.61.0 Pre-release in some video formats, when the image is paused, it is sharp
but when I press the triangle to play it, the image becomes blurry.
So why is this so?
It is known that when the image moves, it becomes blurry in every player, but the date and time numbers should be sharp.
In the place of the film, where a fragment of the film was cut in the Media Player Classic - Black Edition, some colored squares appear in the image right after the cut.
but the system movie player "Movies and TV" in the place where the fragment of the movie cut by LosslessCut begins, the "Movies and TV" player will jam.
Which program can be used to cut movie fragments without encoding so that the movie previews are sharp and that after cutting these fragments, every media player will play them correctly.
File information
filename: 'C:\\FFOutput\\ghjghj.mp4',
nb_streams: 2,
nb_programs: 0,
format_name: 'mov,mp4,m4a,3gp,3g2,mj2',
format_long_name: 'QuickTime / MOV',
start_time: '0.000000',
duration: '3053.222969',
bit_rate: '5268354',
probe_score: 100,
tags: {
major_brand: 'isom',
minor_version: '512',
compatible_brands: 'isomiso2mp41',
encoder: 'Lavf60.3.100',
Video: HEVC 1920x1080 25fps [Video 1 (HEVC, Main Profile, Level 4.0, 1920x1080, 25.000 fps)]
Audio: AAC 44100Hz 2.0 chn 128 kbit/s [Audio 1 (AAC, 44.1 kHz, 2.0 chn, 16 bit, 128 kbit/s)]
Ogólne
Pełna ścieżka : C:\FFOutput\ghjghj.mp4
Format : MPEG-4
Profil formatu : Base Media
ID kodeka : isom (isom/iso2/mp41)
Rozmiar pliku : 1,87 GB
Czas trwania : 50 min 53s
Całkowita przepływność bitów : 5.268 kb/s
Szybkość wyświetlania klatek : 25,000 kl/s
Aplikacja zapisująca : Lavf60.3.100
Wideo
Format : HEVC
Format/Informacja : High Efficiency Video Coding
Profil formatu : Main@L4@Main
ID kodeka : hvc1
ID kodeka/Informacja : High Efficiency Video Coding
Source duration : 50 min 53s
Przepływność bitów : 4.923 kb/s
Przepływność maksymalna : 5.134 kb/s
Szerokość : 1.920 pikseli
Wysokość : 1.080 pikseli
Proporcje obrazu : 16:9
Tryb wyświetlania klatek : Stały
Color space : YUV
Chroma subsampling : 4:2:0 (Type 1)
Bit depth : 8 bitów
Rodzaj skanu : Progresywny
bity/(piksele*ramki) : 0.095
Rozmiar strumienia : 1,75 GB (93%)
Source stream size : 1,82 GB (97%)
Biblioteka zapisująca : x265 3.2:[Windows][GCC 8.3.0][64 bit] 8bit
Ustawienia kodowania : cpuid=1111039 / frame-threads=2 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=1920x1080 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=25 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=20 / lookahead-slices=6 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=1 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=3 / selective-sao=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=5170 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=1 / colorprim=2 / transfer=2 / colormatrix=5 / chromaloc=1 / chromaloc-top=1 / chromaloc-bottom=1 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=255 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Color range : Full
Matrix coefficients : BT.470 System B/G
Codec configuration box : hvcC
Audio
Format : AAC LC
Format/Informacja : Advanced Audio Codec Low Complexity
ID kodeka : mp4a-40-2
Czas trwania : 50 min 52s
Rodzaj przepływności : Stała
Przepływność bitów : 128 kb/s
Kanały : 2 kanały
Channel layout : L R
Częstotliwość próbkowania : 44,1 kHz
Szybkość wyświetlania klatek : 43,066 kl/s (1024 SPF)
Compression mode : Lossy
Rozmiar strumienia : 46,6 MiB (2%)
Default : Tak
Alternate group : 1
So why is this so?
