There a way to secure Apache 2.0 for LAN-use only?
Kaido
Feb 14, 2004
50,965
6,894
I'm running Apache 2.0 on an XP Home box on a LAN with WAN access. I only want Apache to be used on the LAN for now. Is there some kind of config file that I can modify to allow this?
nweaver
6,813
httpd.conf
allow only access from your private network address (it's in there, scroll down).
Unless you replaced the httpd.conf (may be apache.conf, depending on versions, etc) it's well commented.
Kaido
Feb 14, 2004
50,965
6,894
Originally posted by: nweaver
httpd.conf
I'm using XAMPP as a testbed, so placement is a bit screwy. I'll find it, thank you!
Oct 19, 2000
17,860
4
I am very limited in knowledge, but it was always my understanding that Apache was configured, at default, to only be accessible on the network. You only had to fool with the conf file to open it up to the net.
Crusty
12,684
Not sure on 2.0, but the default install of 1.3 in debian opens it up to everyone, unless you have a firewall. In that case you also have to open the port on the firewall.
n0cmonkey
42,936
Apache 2 is configured to accept all connections by default.
