Originally posted by: tommo123
How in theory could you gain power from black holes? I thought they basically sucked everything in. Or is it 'hawking radiation' or whatever they think black holes spew out that they use for power?
a bit random i know
read that scale thing on wiki aaages ago. forgot about that. wonder if we'll survive that long
a bit random i know
Eric:
This means that the size goes to zero and thus the density goes to infinity -- note that this is not just a mathematical singularity but a real physical one.
A real physical one ?
has this ever been proven ?
This is the whole point however, because the singularity is hidden behind the event horizon it is ok that the density can reach an infinite value -- if you are worried about infinities try looking at the standard model and quantum gravity...
In fact, if you take the schwarzschild radius for the supermassive black hole at the center of the galaxy and compute the density for the entire thing you get a number that is less dense than water. You probably wouldn't even notice falling into one of them.
I hope this helps.
You could have attempted to answer my rhetorical question to save yourself a bit of typing:
If a black hole is truly a "singularity" and has INFINITE density and mass, then there can only be ONE type of black hole. It would not be possible for there to be a "super massive" black hole and a "normal" black hole because both are equally infinite. Apparently that is not the case, as not all black holes are equal in their mass.
Spouting little understood quantum theory is hardly going to support your position. It seems like quantum theory is the scientific way of attributing something to a deity without sounding religious.
If you want to know why infinity as a solution FAILS, just imagine an infinite number line. No matter how far you move in either direction on the number line you will always be at position zero. Infinity renders math useless when attempting to describe something like a black hole because it reduces it to an "all or nothing" type of solution.
A singularity can either exist, or not exist - there cannot be multiple "grades" of singularities and we have already observed that black holes are not all identically massive. They are not singularities.
If a black hole has finite mass and zero volume (not "very small," zero) then the density would be infinite, right? Dividing by zero is always messy.But this certainly allows black holes of different mass, but all with infinite density.
Yes, your statement could explain the existence of a black hole with infinite density and limited mass, but it doesn't cover all of the bases. While the forces that create a black hole are great, for gases and other stellar matter to be compressed into something that is infinitely dense, the force acting upon them to form the compression would need to be be equally "infinite"...something that doesn't seem likely given the finite quantity of mass within the object.
Other issues with infinitely dense matter:
- It would occupy no space.
- It would have no temperature (no heat whatsoever)
- All of the matter that created it would somehow become one "particle" of sorts...i.e. it vanishes.
- If the particle comes into contact with other matter then it should grow like a snowball, but black holes with plasma gets release matter - something that should not happen if there is an "infinite" force at work.
Again, this is not correct. I outlined how a star is supported through pressure, that pressure is finite and a particular value based on the number of the specific particle in the star. If the star has too much stuff in it then the gravitational force is larger than the pressure force and the star collapses. We have ample evidence for white dwarfs and neutron stars that agree quite well with our assumptions. If there is another kind of pressure able to support the star after neutron/quark degeneracy it would be too late to keep the stars radius beyond the schwarzschild radius where it becomes a black hole. Nowhere does this need an infinite force, only gravity. Infinite density =/= infinite force.
Again, the gas and stellar matter are converted into other forms of matter which can occupy a smaller and smaller volume. Eventually even this is not enough and the whole thing collapses to a point -- thus the infinite density.
That it sort of becomes a really heavy particle is correct. Again this aspect is open to some debate. Since the only things which define a black hole uniquely are its mass, spin(rotation), and charge they can be thought of as elementary particles. (electrons for instance have mass, charge, spin and also have no size)
Why would it behaving like a particle mean that it vanishes?
Again, first part is true but the second part does not follow. Anything that goes past the event horizon does not come out and is added to the black hole mass.
Once again the relativistic jets from black holes do not come from the black hole but rather the disk of matter surrounding the event horizon that is falling in on it.
The thing that always fascinated me about black holes was that you'd have matter, which does have size, "falling in" and all of a sudden not occupying any space at all.
For instance, do quarks have size (2-dimensional area or 3-dimensional volume)? If so, how do they, or the things made of them -- protons, neutrons, etc -- lose that when they collapse into a black hole? I suppose like anyone else, I have trouble with infinities because on the macroscopic level, we're talking about cramming 1001 1mL cubes into a 1L container. It wouldn't fit macroscopically. How does it fit?
If you truly believe that quantum mechanics is wrong and these particles don't exist etc., and I stress the word believe, then I can do nothing to sway your faith. You'll have a lot of work ahead of you if you intend to come up with a new theory of quantum gravity and I wish you luck.
For the record I think the original question has been answered and now its just a philisophical debate.
So much fail.![]()
Infinite is mathematical. Mass/0 volume = infinite.
Once we identify the property/particle/effect/doohicky that makes particles not take up the same position in space/time and prove that it is either negated/removed/overpowered in a black hole, we will never know.
