Theme Generator v2 for Pocket PC does not load on in XP - Help
NewRipper
just downloaded a Themegenerator program from Microsoft.("theme generator v2.msi")
At work (XPP/Sp1), I can see the program in the whole screen. And all the button and so use it.
AT home (XPH/Sp2 Nvidia GeForce GeFX5650), the same program (copy of the program at work) is minimised to a small rectangle 1/5th the size of full screen. The maximise button is grayed out and I cannot scroll up/down or sideways either. Hence, the buttons at the bottom are not accessible.
I have tried changing the screen resolution (From 1680 x 1050 all the way down to 800 x600) but it does not help.
Is there a problem with the way Sp2 is handling the installation? I also have Spybot S&D installed. However, I tried by diabling teh firewall and Spybot - no luck
Why is the same program behaving differently? Could it be that XPH in conjunction with my display settings or Sp2 is making the program behave in this strange way.
While it says registering the product on installation, Searching through the registry, I found nothing that relates to ThemeGenerator - there is no registry entry.
How can I rectify it? Please help!!!
Thanks in advance
An Inexperienced user
