The camera that photographed the abomb explosions used the fact that a magnetic field can rotate polarized light. the camera was fitted with 2 polarizers at 90 degrees to each other. in between the filters, a magnetic field was rapidly switched on and off. When off, no light would pass through the 2 filters. when the field was on, the light coming out of the first filter was rotated 90 degrees so as to align with the second filter, resulting in light transmission. Because the field could be switched on and off at intervals of around the nanosecond or picosecond scale (i forget that detail) the first images of the atomic explosion at the instant of detonation were recorded.
It looks like a white hot ball of swiss cheese with big holes. (in contrast to the bleu cheese that makes up the moon)
