THe Sandia Cooler - Breakthrough in Air Cooling design
Discussion in 'CPUs and Overclocking' started by Arkadrel, Jul 13, 2011.
  1. Keysplayr
    Keysplayr Elite Member
    Jan 16, 2003
    21,200
    48
    I just don't see how, if the heat sink fins themselves are spinning, the heat from the semi can be successfully transferred to the moving fins. How does the heat get to the fins? A spindle in the center? How much heat can that actually carry? And lubrication. What compound can not only lubricate, but allow the transfer of so much heat?
    I'm thinking this isn't going to be anywhere near as efficient as they say it is.
  2. Phynaz
    Phynaz Diamond Member
    Mar 13, 2006
    9,829
    623
    Keys didn't RTFA.
    The lubricant is air.
  3. Puppies04
    Puppies04 Diamond Member
    Apr 25, 2011
    5,911
    9
    try reading the link or at least reading the thread.
  4. KingFatty
    KingFatty Diamond Member
    Dec 29, 2010
    3,027
    Well all understand that heat can xfer from our current heatsink fins to the air blown by the fan.
    Now, try to think how that can go either direction, it's reversible.
    So you have one heated metal xfer heat to the airstream. You get hot air. But that hot airstream passes over another set of cool fins. The heat is xfered from the hot air to the cool fins.
    So heat passes from one thing to another. It's not a one-way street. Heat goes downhill from hotter things to cooler things.
    That's what the air bearing does, it lets heat go from one metal piece to air to another metal piece. That's how the heat crosses the air bearing.
  5. Ferzerp
    Ferzerp Diamond Member
    Oct 12, 1999
    6,350
    46
    It's snake-oil looking for investors is all. That's all that's ever been. There is no benefit to spinning the whole heatsink, even if you could transfer heat to it just as fast as a normal set up.
  6. Phynaz
    Mar 13, 2006
    9,829
    623
    Sandia Labs is looking for investors?
    They have plenty of cash, called your tax dollars.
  7. Phynaz
    Mar 13, 2006
    9,829
    623
  8. Keysplayr
    Jan 16, 2003
    21,200
    48
    You're 100% correct. I didn't. Just by looking at it screams poor heat transfer from semi to heatsink.
    The lubricant is air? Even worse. What happens when there are air gaps between heatsink and heatshield in today's heatsink applications?
    #158 Keysplayr, Nov 5, 2012
  9. Gideon
    Gideon Senior member
    Nov 27, 2007
    203
    100
    The gap is only 0.001". And unlike conventional coolers it is between two metallic surfaces (held together by magnetic attraction) with one spinning at 2000 RPM.
    Here is a nice short PDF about the design which FAQ section provides good information and links to how the "air bearing" design works:
    https://ip.sandia.gov/techpdfs/Sandia Cooler- Fact Sheet for the Microelectronics Market.pdf
    They do mention in the video, that initially there was a lot of scepticism about the design and since the very same question is the first in the FAQ section, you're probably not the first one to point it out :)
    It is important to understand that it's not someones brainfart they hacked together in a weekend on the off change that it might work. It is a result of years of complex fluid-dynamics modelling, trying hundreds of different designs, finding one that does work the best in the models. Without any prototypes scepticism might be well founded ... but rototypes have been built and the modelling IS backed up by experimental data.
    By June they had at least 2 licencees to the design (one in CPU cooling). wouldn't you think that CPU cooler companies don't simply throw money away on revolutionary (and iffy) designs before seeing hard, real-life data to back them up ?
  10. cytg111
    cytg111 Diamond Member
    Mar 17, 2008
    4,239
    573
    ... I am not quite sure I see this happening .. or its claimed effectiveness.
  11. KingFatty
    Dec 29, 2010
    3,027
    Well, you gotta admit, in our current coolers, the potential of the plastic fan is untapped.
    I mean we have plastic spinning fans that do not transfer any heat from themselves, they just push air toward a stationary heatsink.
    But what if the plastic fan was instead metal, and could help transfer heat from itself (if thermally interfacing the heat source)? That's a huge potential, and this Sandia design captures that potential.
    That's a big deal.
  12. veri745
    veri745 Golden Member
    Oct 11, 2007
    1,158
    4
    I don't think it's quite as simple as making the fan metal instead of plastic.
    Instead of pushing air past stationary fins, the sandia cooler is using rotational acceleration to decrease the "dead air gap" (as it is described in the video), and the the fins being shaped into an impeller pulls in cooler air to improve heat transfer. None of that would happen if you just took a HSF and make the fan metal.
  13. SlowSpyder
    SlowSpyder Lifer
    Jan 12, 2005
    10,700
    140
    I'm wth you, I just don't see it working as advertised.
    I don't have time to read up on it now, but what happens as dust builds up on the fins? Will that throw it off balance enough that it wobbles, just a bit, and the .001 does become an issue?
    I guess we'll have to wait and see if anything comes of this, but it has some problems in my mind.
  14. KingFatty
    Dec 29, 2010
    3,027
    After watching the video, I didn't like how the dust issue was dismissed with "it will be flung off." We all know how our current fans are spinning and they still collect dust on them.
    I guess it makes sense that the weight of the dust is negligible compared to the weight of the spinning heavy impeller, so even if the dust build-up causes lop-sided weight, the impeller won't really notice or get thrown off (and the air bearing is probably immune to wobble, the bearing holds the tolerance, not the other way around and I think that non-intuitiveness is throwing-off a lot of readers who think the precise tolerance is needed for the bearing, that's backwards). Anyway, it also seems reasonable that dust will build-up on the impeller symmetrically so it's still a non-issue of dust build up. But why didn't they mention these things instead of dismissing dust?
  15. 9enesis
    9enesis Member
    Oct 14, 2012
    77
    too much friction and one might end up with a heater;)
    from the link it looks like .... nonsense....tbh.
  16. 9enesis
    9enesis Member
    Oct 14, 2012
    77
    #166 9enesis, Nov 5, 2012
  17. Hubb1e
    Hubb1e Senior member
    Aug 25, 2011
    397
    Just because you can't figure out how it works based on your high school physics background doesn't mean that it doesn't work.
  18. 9enesis
    9enesis Member
    Oct 14, 2012
    77
    did you address this to me?
  19. Haserath
    Haserath Senior member
    Sep 12, 2010
    794
    Sometimes things aren't always as they seem?
    Do the math, then tell us whether it sucks or not.
  20. RampantAndroid
    RampantAndroid Diamond Member
    Jun 27, 2004
    6,591
    Well, the issue is heat transfer, straight up. Did anyone pick up on the "dust won't stick to this because it's moving so fast" comment? That's complete BS, it WILL get dust on it, in use and more than that, when off. What happens if dust gets into that air gap? Lab testing is one thing, real world performance is another.
  21. LightField
    LightField Member
    Feb 12, 2013
    113
    No one is going to believe this but yesterday I had this very same exact idea... and then today I was doing a search related to cleaning the inside of a pc and just randomly came across this....
  22. Borealis7
    Borealis7 Platinum Member
    Oct 19, 2006
    2,505
    32
    it's still vaporware. i wonder what will be out first: the commercial application of this, or Duke Nuke'm Forever...
  23. NTMBK
    NTMBK Diamond Member
    Nov 14, 2011
    7,550
    400
    Erm. Duke Nukem Forever came out already.
  24. VirtualLarry
    VirtualLarry Lifer
    Aug 25, 2001
    38,185
    1,916
    Duke Nukem Forever WAS released. Didn't you get the memo? :)
  25. Borealis7
    Oct 19, 2006
    2,505
    32
    the factory called, NTMBK and VirtualLarry models are being recalled to get their humor upgraded.
