Thank you for the share.here is a q & a with the inventor http://www.extremetech.com/computin...tsink-your-questions-answered-by-the-inventor
anyway it did remind me of one other failure with the design, the fact that it consumes between 10-20 times as much power as the average 120mm fan. if you put one of those delta 220cfm fans on a regular tower heatsink it would definitely be under .1 c/w, while consuming about the same amount of power.
sourceWe expect to have 5 W of motor power consumption in the mature prototype (Right now the figure is just over 6 W.).
There must be something lost in translation here, the device does not use 100W, it's more like 1-2X the power usage of a 120mm fan.
source
Assuming my research is correct, 2008 DARPA MACE is a contest of HS design. "State of the art performance" is defined as follows. the device must be able to cool a heat source powered with 1,000 watt and ambient temp of 30c. Each design must not use more than 100Watt, smaller than 4inch^3, lighter than 800g and thermal resistance of .2 c/w.according to their own pdf it consumed 20w in lab tests @ .2 c/w, its on page 15.
also the point about the 100w claim was in regards to the darpa cooler. if you read the link i posted under it you would have seen that was false.
i don't know, but i found the website for it https://ip.sandia.gov/technology.xhtml?techID=66
looks like it was last updated 9/26/2011
The gap is only 30 micron, so those particles would have to be very small to get in there. And at that scale the rotating discs have a phenomenal speed, so it would rip them apart into even smaller particles. These discs are metal, so anything softer than metal would get obliterated. Anything harder than metal, well, you don't want that floating around freely anyway since it would probably be carcinogenic. :hmm:I don't think anyone has adequately addressed the question I had over on the Cases & Cooling thread on this: What happens when a dirt particle gets stuck in the gap. Screeeeeeeeeeeeeech... Sizzlesizzlesizzle...
You do know that a typical grain of sand is considerably larger than 30 micron, right?You do know that a grain of sand is considerably harder than metal, right?
Sand particles can be made smaller into a kind of dust or powder, but inhaling that stuff makes you very sick.
It's also a matter of quantity. One such grinding dust particle won't damage this cooler (or your lungs) in any significant way. You need billions of them and it can take a lifetime to see any effect from the amount of naturally occurring particles.
Someones gonna lose a finger, watch or get cut bad.
I suppose, the tobacco market is much more lucrative and desired, though. With the power consumption slowly but steadily going down, I don't see an imminent need in such advanced researches. Just poor ROI, imo.what they need to do is forget about fans. The cpu's company's need to invest in finding some kind of unheatable metal alloy , similiar to the type of wood that is used in making tobbacco pipes, the wood itself is fireproof but is still wood.
that's what we've been hearing, but please tell me, how hot is an overclocked 3770K at load?With the power consumption slowly but steadily going down, I don't see an imminent need in such advanced researches.
Within the specs and design parameters.that's what we've been hearing, but please tell me, how hot is an overclocked 3770K at load?
