Question The perfect SOHO switch? (QSW-2104-2T-US) 2x 10gbe + 4x 2.5gbe from QNAP for $159 (AMZN) / $169 (B&H)
VirtualLarry
56,587
10,225
They also have a version with 2x SFP+ 10gbe.
Reactions: Ranulf
VirtualLarry
56,587
10,225
B&H has both listed with a 7-14 day lead time for orders:
$159:
$129 for the SFP+ model:
VirtualLarry
56,587
10,225
Solid find! Looks like 2.5Gb upgrade options are really coming down in price. :)
Yep. I was hoping that Zyxel would have come out with a variant of their 8x 1gbe + 2x 10gbe + 1x SFP+ switch, managed or unmanaged, with instead, 8x 2.5gbe. That would have been ideal to me. For $200 or under.
I wasn't entirely enthralled with purchasing a pair of 8x 2.5gbe TrendNet switches, with NO 10gbe uplink / trunk ports, for close to $200.
Thankfully QNAP to the rescue, with the current switch in the OP.
Reactions: SamirD
VirtualLarry
56,587
10,225
This one's kind of neat too. 16x 2.5gbe POE+ + 2x 10gbe POE++ + 2x SFP+.
Probably around or over $1000.
B&H has it listed as "Special Order - Notify When Available", for $599.
Edit: A little commentary, the D-Link managed rack-mountable switch with 8x 2.5gbe and 2x 10gbe SFP+ is around $550 on Amazon, and it doesn't have POE (there is another variant that does, for a little more).
So $599 for 16x 2.5gbe with POE is quite competitive.
Reactions: SamirD
SamirD
1,489
276
www.huntsvillecarscene.com
Nice, but these are far more than the used 10Gb enterprise sfp+ switches out there. Of course there would be a cost to 10Gb nics and sfp and fibre (or dacs), but in the end it would cost probably about the same but be far faster.
And this is the issue that has plagued 2.5/5Gb from the beginning--10Gb can be cheaper in a lot of situations. It's getting to be less of an issue as 2.5Gb stuff comes into market simply replacing 1Gb, but as you've pointed out with these switch deals, the switching side of it is still not doing that yet so prices aren't as competitive with 10Gb.
Reactions: VirtualLarry
VirtualLarry
56,587
10,225
Among the problems that I see with enterprise 10G gear, is it is almost always 1/10G, and not "multi-gig", which, even if Joe buys a new mobo with 2.5gbe built-in, doesn't do him a lick of good. To say nothing of the expense of ripping and replacing good Cat5E, and having to buy sFP+ to copper trancievers, which also many don't support multi-gig.
There's a real reason why consumers choose consumer-oriented NAS builds, rather than the "more for your money" solutions involving cast-off enterprise rack-mounted servers running unRAID. Now, enthusiasts who know how to get the most out of hardware, might choose the latter, but your average Joe consumer wants something small and quiet that doesn't interfere with the decor. Not everyone owns a rack.
The same is true for networking gear.
mv2devnull
1,535
167
Fair point, for now. Google finds couple "2.5GBase-T transceivers". About á $30.
QSW-2104-2S is cheaper than QSW-2104-2T. You can afford one transceiver with the difference?
Fallen Kell
555
Not all enterprise 10G gear has this problem. Case in point, the Brocade ICX6610 that I run has no problems running most of the SFP+ to NBase-T transceivers out there. I have 2 of the Wiitek ones, and 1 Microtik, all of which work at either 1, 2.5, 5, or 10gbe speeds. This is yet another reason I love this switch. Sure, there are many switches out there that will not work correctly with NBase-T transceivers, but those are switches that are typically picky about what transceivers they work with in general (looking at you CISCO and HP).
Also, you don't need to rip and replace Cat5E to buy a SFP+ transceiver, you simply connect the transceiver into the switch, and then the Cat5E into the transceiver. Cat5E will limit you on distance, but I think for 2.5gbe, it is something like 100feet.
Reactions: bp_968
fkoehler
214
175
Dang, that Brocade seems like it might replace my Cisco. Don't really care about the 2.5, however $100 for Brocade ICX6610 with 8 1/10 SFP's is sweet for 100-200. I've got about 25 NIB SFP's which have been sitting alone and in the cold for 5 years... Sigh, looks like you need a licen$e to get the 10g SFP's working.
Fallen Kell
555
Go read the master thread over on serve the home forums under their networking forum on the brocade ICX switches and follow the instructions.
VirtualLarry
56,587
10,225
According to that, could I buy that switch and safely use it with both PoE drives AND non-PoE devices?
mxnerd
6,799
1,103
Netgear claimed that its POE devices are all active.
Initially, it might seem like a good idea to opt for passive PoE over the industry-standard active PoE, but it could very well end up costing you a lot more, in the long run. The only way to ensure complete compatibility with the majority of PoE devices on the market is to stick with the industry standard, active PoE.
Do not mix with Unifi passive 24v POE devices though according to the post here
