- Sep 23, 2003
- 11,448
- 262
- 126
Try to take a similar picture of your laptop and a reflective surface.
Exactly. The dead give away is the hand which is what makes it easy to pick out.
Also another dead give away is the size of the reflection is (visually) nearly exactly the same size as the original that sits on the table. This isn't going to happen, it should be slightly skewed.
The only thing that would make sense to me would be that the reflective surface is tilted up (the part closest to the camera), but then the case can't sit flat or you need 2 surfaces.
So ultimately the way they did the image, the image on the Ipad would have to go directly through the keyboard.
