The lightbulbs in my track lighting keep burning out...
Philippine Mango
5,594
I've noticed in the past years that the three main lamps in my track lighting which lights my room tend to burn out fairly quickly (all three bulbs about 3 times a year) and I can't seem to figure out why. I think my voltages are stable (used killowatt device for computer and reported like 115v...) Yes I do tend to leave them on all night long but I don't believe thats an excuse for them to burn out because technically turning them off and on would stress them out more. These are 60 watt flood light bulbs...
mobobuff
11,099
In my experience, floodlight bulbs always burn out faster than regular lamp bulbs.
But leaving them on when they don't need to be on is a sure way to have them go much quicker.
Zim Hosein
Super Moderator | Elite Member
65,461
408
Topic Title: The lightbulbs in my track lighting keep burning out...
<-- Prays your computer PS burns out next! :evil:
SarcasticDwarf
9,574
In my last car I had a similar problem. I eventually figured out that condensation was building up inside the light box, causing it to splash onto the bulb after heating.
Zim Hosein
65,461
408
we should start a church...
Amen, but no molestation of young boys okay? :evil:
Midlander
2,456
I've had the same problem. In addition, sometimes when the bulbs go, they take the dimmer switch with them. That's a bit more expensive than just changing the bulb.
Eli
8
How many hours are the bulbs rated for?
Are you using the correct wattage for the fixtures?
Midlander
2,456
I am. They just go fast. I've had electricians check it out, too. They don't know what's going on. No pun intended.
Zim Hosein
65,461
408
agreed.....young men is okay though right?
:Q
Eli
8
Well, there's no way to tell if it's abnormal without knowing the bulbs rated lifetime.
If they're rated for 750 hours and they're constantly burning out after like 300, then there is a problem.
Eli
8
Originally posted by: Philippine Mango
They're rated for like 2000 hours so...
Ahh..
well, being on 24/7.. that would only be about 3 months ...
So if thats the case, it sounds about right.
If they're on for 12 hours a day, they should be lasting about 5-6 months..
I don't think you're too far out of spec unless they're really only burning for a few hours a day and you still have to replace them that often.
Philippine Mango
5,594
Ahh..
Agreed, now that I think about it, they're well within spec which is kind of sad because it shows how often I'm in my room:( Another reason why I leave it on is because if I need to do work but I'm too tired, I'm more likely to wakeup if the lights are on than otherwise.
MWink
Why not replace them with compact fluorescent flood lights? They last longer, use less electricity, produce less heat, etc. The only down side is when the die you have to recycle them because they contain mercury.
Eli
8
laff
Kinda like how everyone recycles all other fluorescent bulbs, eh? lol
Granted, it's a good idea.. but still.
Philippine Mango
5,594
I've tried them and they're utter POS, they look more like super novas than actual suns.... They extremely bright when looking at but don't light up the room what so ever.
Vette73
21,503
9
Try another brand. I put in ressesed lights at my girls place and we use the GE version. Uses like 14 watts but after 30 seconds or so become just as bright as the 60watt ones. Since they make less heat and by design, they last much longer. A 5 pack at sams was around $16 or so.
