- Jul 18, 2001
- 92
- 0
- 0
Ok, this is basically what I have done in small easy steps.. and a nagging feeling that I haven't overclocked it enough is haunting me, so any pointers are appreciated.
Pre-steps - Decide if you want to go overboard with watercooling, keep it cool with bigger better air cooling, or just dip your toes in by not enhancing your pc with addons. With me I took away the aluminum heatsink for the more robust thermalright sk6 and a delta 30cfm.
The heat before I installed the thing was:
CPU idle: 46 celsius - CPU max: 51 celsius
system temperature always the same 27 degrees celsius
Installing the sk6 was easy, but I made the mistake of putting too little arctic silver II between the heatsink and cpu, but by taking the heatsink off, adding more to the cpu, cleaning the heatsink I got much nicer, LOWER numbers.
Now here's what I did then:
1. increased the FSB until 3dmark2001 started to freeze, then lowered it until stable again.
2. increased the multiplier until freezing happened, then lowered it until stable again.
3. then I increased the core value and I/O voltage value and tried 1. and 2. again until it keeps getting locked up.
Now my goal by overclocking is to get my pc beyond the 6000 mark in 3dmark2001, and I'm pretty close to it (even gone over it a couple of time with oc-ing).. here are my specs :
Athlon 1333 MHZ @ 1485 (can't remember the last digit, was over 5 though)
- Vcore value 1.80
- I/O Value 3.60
Idle temp : 43 celsius (idle isn't that important.. or is it?)
max temp : 47
system temp : 27
Even though I've overclocked, and the heat isn't going over 47 (which it used to with old heatsink), why can't I overclock it more ???? I thought I might hit 1500-1600 mhz, but I'm barely able to hit 1500..
I've been tempted to up the voltage more, but how much is too much ? Is it safe to up it as far as the mobo allowes ? and what artifacts does increasing the voltage have ? (basically what should I be looking out for?). And should I up both of them at once, or one first, and then the other ? This is an area unexplored by me, so anyone with experience, please help
stan.
- Vcore value 1.80
- I/O Value 3.60
max temp : 47
system temp : 27
stan.
