the front audio and usb connections.
lostone510
35
I wanted to know if anyone knows a way to tell what goes where when connecting the front port audio/usb cables of the case to the board. Ive done a couple of comps and the way i do it is trial and error and it gets annoying. I look at the manuals and everytime they say each cable represents different things. So i wanted to know if anyone knows a way to make it easier. thanks
madthumbs
Banned
Oct 1, 2000
2,680
I don't understand the question, but to say that if you wire the usb wrong; you could end up frying it permanently.
Cheetah8799
4,508
I assume you have the problem where the case wires aren't molded together and you have a bunch of different little black connectors that have be in the right order on the motherboard.
Well, each little black connector should be labeled. From there you have to look at the manual for your motherboard, it'll say which pin they go into. It's a real pain in the butt, but that's how it's done.
If you do it wrong, well, USB won't work, and I've had motherboards where the sound won't work at all if you have those wires not plugged in, or in the wrong order.
