Originally posted by: ScrapSilicon
the fan on the hs has(usually) a lil direction arrow to denote rotation direction and airflow direction..so..it depends on which its mounted..some blow down ..some blow up and away..
Originally posted by: jmebonner
Mark is correct. If you have an newer computer (which tend sto have higher temps :cpu, gpu, psu, ram, etc, etc...) and you don't have any outside fans blowing in or big vents from which to draw cooler air to force into the HS, then you'd probably do better blowing away from the cpu. By and large, though, it's better off blowing onto the cpu.
reworked a Celeron 533 Compaq to use a matx via mobo w/ Duron..the hsf ended up with blowing upwards as the psu's intake was 1/2" off the top of said fan.. 😀
My english teacher always said " Blow before suck, except in certain unusual situations, and that's definitely one of those unusual situations 🙂
wait, wait, that was i before e
Oh well, same rule applies 🙂
