The F-35 is a piece of garbage!
irishScott
21,562
good thing dogfights are basically a thing of the past. if the F35 lost a missile engagement, then i'd be extremely concerned.
They are for now. The issue is if we adopt the F-35, use it for 30 years and sometime in those 30 years encounter a dogfight.
The problem is the US military has been alone at the top for over a generation. The last time we faced a military threat we couldn't roll over was Vietnam. As a result most new hardware is a bunch of solutions looking for problems, and much of it ends up tripping over itself.
cabri
3,616
Link
June 30, 2015
F35 loses to 1970's era F16 carrying weights in a dogfight
air force, airplanes, future weapons, geopolitics, military, technology, united states, world
There is a report from a F35 test pilot in a report obtained by War is Boring's David Axe.
A single-seat F-35A with the designation “AF-02” — one of the older JSFs (Joint Strike Fighters) in the Air Force — took off alongside a two-seat F-16D Block 40, one of the types of planes the F-35 is supposed to replace.
The F-35 was flying “clean,” with no weapons in its bomb bay or under its wings and fuselage. The F-16, by contrast, was hauling two bulky underwing drop tanks, putting the older jet at an aerodynamic disadvantage.
But the JSF’s advantage didn’t actually help in the end. The stealth fighter proved too sluggish to reliably defeat the F-16, even with the F-16 lugging extra fuel tanks. “Even with the limited F-16 target configuration, the F-35A remained at a distinct energy disadvantage for every engagement,” the pilot reported.
“Insufficient pitch rate.” “Energy deficit to the bandit would increase over time.” “The flying qualities in the blended region (20–26 degrees AoA) were not intuitive or favorable.”
The F-35 jockey tried to target the F-16 with the stealth jet’s 25-millimeter cannon, but the smaller F-16 easily dodged. “Instead of catching the bandit off-guard by rapidly pull aft to achieve lead, the nose rate was slow, allowing him to easily time his jink prior to a gun solution,” the JSF pilot complained.
The F-35 — the only new fighter jet that America and most of its allies are developing — is demonstrably inferior in a dogfight with the F-16, which the U.S. Air Force first acquired in the late 1970s.
The test pilot explained that he has also flown 1980s-vintage F-15E fighter-bombers and found the F-35 to be “substantially inferior” to the older plane when it comes to managing energy in a close battle.
- F35 program costing a trillion dollars
The best option for an F35 pilot in a dogfight is the ejection seat.
Reactions: shortylickens
jlee
48,517
223
Heh, I just read that the F35 only carries 120 rounds for its gun. That's five 0.5 second bursts...
mmntech
17,501
12
The F-35 is still cheaper than the F-22, which is most likely why it won out. I'm guessing the USAF is betting that its stealth capabilities will help it avoid dogfighting all together.
Apparently the last dogfight the US was involved in was in the 1999 Kosovo War. Most pilots don't want to get involved in direct combat. Now has the US really been facing any enemies with any serious areal warfare capabilities. Fighters have largely shifted to ground attack rolls over the last few decades. So dogfighting capability doesn't matter as much as it used to.
Not that it makes up for the F-35 being what it is. For such an expensive hunk of junk, I'm surprised it wasn't German engineered.
irishScott
21,562
It was. With all the delays and cost overruns it's about at parity IIRC, and the F-22 is a decidedly superior aircraft. Granted if they finally pull the program's head out of its ass it'll be cheaper plane-for-plane and the total costs will go down, but that end is a long way off by the looks of it.
NesuD
I can't imagine an enemy fighter ever getting within visual range of an f35 undetected in the first place. How likely is a visual dogfight scenario considering the f35s ability to detect and identify the enemy at extreme distances.
TheSlamma
7,625
Pretty bad it can't beat the F-16.. man those things are pilot killers. We need a replacement for it bad.
bononos
3,909
171
Apparently the last dogfight the US was involved in was in the 1999 Kosovo War. Most pilots don't want to get involved in direct combat.......
I doubt that pilots want to avoid combat. The push is from upstairs trying to make the airforce more of a video game with drones and being able to cut costs.
irishScott
21,562
Replace that with "guided missiles" and you have the anti-dogfighting argument from the Vietnam era.
All it would take is for some other nation to figure out rudimentary stealth tech or some other way to throw off the system. Even as far behind as China and Russia are they're starting to catch up. We figured out stealth tech in the 80s. They'll probably have it in 10-20 years.
The problem isn't what the F-35 will face today, it's what it'll face over the course of a multi-decade service life. That could very well include some dogfights.
Murloc
5,382
65
But pieces of it are made in almost every state, making it impossible to kill.
the same is happening in Italy, they promised them to build the wings in a factory in the south (it's a poor area) and now people keep trying to justify wasting money on this plane instead of going with the european program (that would feed european companies) only because of that damn factory, that provides no useful technology transfer but these people are stuck in the 60s with the glory of national car manufacturing in mind and completely ignore the importance of knowledge economy.
There is one party that wants to cut down on that program but it's not in power.
Luckily my country is neutral so the F-35 never entered into the equation anyway.
manimal
13,559
8
They should just keep retrofitting existing airframes and work on lowering costs and integrating remote control.
Who cares if we send up 20 state of the art planes costing 200 million each when we could send up 200 older frames sans pilots being controlled like a swarm.
They need to invest in more tech for AWACS and make cruise missles cheaper.
Really cheap cruise missles and drones would extend our ability over entire regions instead of playing whack a mole.
Simulations are playing this out and the establishment keeps digging their heels.
Procurement process sucks and will keep sucking as long as senators have a say.
garndawg
88
Gents,
I've got first-hand knowledge on this, please allow me to interject a little factual info:
F-35 was, first and foremost, an EXPORTABLE fifth generation fighter. Raptor was most definitely NOT going to be approved for FMS, nor should it have been. (Good political decision, that.) F-35 was sold as almost as capable for half the cost of Raptor. (I'll take issue with the "almost" bit of that. And back in 2009, it was supposed to be cheaper.)
The F-35 is not an air superiority aircraft, it's a stealthy bomb truck with self defense capabilities. Adding the STOVL requirement drove design compromises which hinder the "A" and "C" significantly. The Navy is pretty much on record saying they'd rather not buy a single "C" and just keep building F-18E/F's. (BTW, if you think an F-18E/F bears ANYTHING in common with the F-18C/D, think again...)
Manimal, there's been lot's of discussion about various robot/drone air armada type fleets for a while now. Consider, however, how easy is it to jam that control signal? Remember, you're not jamming the _source_ of the signal, you'd be jamming the receptors' antenna...
All that said, the F-35 isn't a bad airplane, it's built for a specific set of requirements.
Flay the requirements all you want...
cabri
3,616
Extreme distance with an AWACS support - you may be correct.
What about a low tech attack from the ground?
The enemy is not going to do what is expected. They will find ways around our high-tech.
Look at the IED problem that we had in Iraq/Afghanistan.
And the stealth fighter that we lost in the Balkans.
Blitzvogel
2,012
23
The future is both manned, unmanned, and optionally manned.
The role of air superiority will distinctly be the role of manned fighters for a while, probably the next 20, 30 years. However, within the decade, expect the first experiments with "escort" UCAVs operating under the command and control of an accompanying two-seat fighter aircraft.
Essentially, we should be developing an "AWACS fighter" with a very large AESA system detecting threats in the 180 cone in front of the plane and data link array to the UCAVs, of which themselves are equipped with their own smaller radar and IRST,etc systems that can be data linked to the command and control fighter for either forward recon and penetration without risking the manned fighter.
These UCAVs could also be optionally manned fighters like the proposed F/A-XX by Boeing where you have versions of an aircraft with pilots, and dedicated UCAV versions.
irishScott
21,562
Gents,
That would be the issue. It was billed as the be-all-end-all fighter of the future for the entire US military and many of its allies. As it stands the Navy has all but rejected it, the delays and cost overruns have effectively made it more expensive than the F-22, and the end is nowhere in sight.
Meanwhile the requirements seem to get more and more "specific", or rather "limited", as the years go by. The design is a failure given its original promises.
Fenixgoon
32,048
10,822
this is what happens when you promise 3 planes for the cost of 1....whoever bought off on that promise was a retard.
Blitzvogel
2,012
23
[/B]
Politicians and the idiot public thinking it was possible.
Past examples of multirole fighters all started out as dedicated fighter aircraft with very limited ground attack, that had over time were adapted and modified for more and more advanced ground attack munitions and capabilities. The F-16 and F-15 come to mind here. The cost of that development came later on, and wasn't lumped into the initial aircraft development, so we got great aircraft for fighter duties, and then modified for fast ground strike.
Also, in the past, ground attack meant dumb iron bombs, rocket pods, and using internal guns which are all relatively cheap munitions that don't require anything more than a change of mode on the gunsight for aiming or just practice. While sensored munitions are less wasteful in terms of success, it means more cost per weapon used and target killed, but it comes back down to success/cost ratio and the cost of procuring the sensors (like the SNIPER pod) or integrating such systems into the aircraft.
Genx87
41,091
513
Then why the 'F' designation and not 'B?'
B designate a strategic mission. This would be an attack aircraft. It could be an FA-35. But in all reality there isnt a need to designate as both. The F-16 and F-15 carry out duel roles and only carry the F.
norseamd
13,990
180
Ns1
55,418
1,597
lol 180 rounds from a GAU-12? What is that like 5 seconds worth?
