The Exploding Shuttle Power Supply Article
Roooooooooooooooooot
19
I dug it up.
I'd really like to find out more about this.
Can I avoid this problem by using a 3.0 instead of a 3.2 GHz P4, an MSI FX5200 instead of an FX5600,
etc. ?
http://www.2cpu.com/hardware/sff/SB75G2/conclusion.html
"Power supply quality? I've had two XPC power supplies die out of three XPCs. I've heard others have had problems as well."
To make a long story short, I'd like to get another Shuttle SFF. It sounds reasonable that loading down
a 225/250 watt power supply will increase the probability of a little bit of pyrotechnics.
Also, can anybody tell me, how can I get this thing to show me all the articles going back more than
a few days ?
I tried, no dice so far.
Thanks !!
Roooooooooooot
MDE
13,199
There's people using overclocked 9800 Pros and overclocking their CPUs without problems, so I wouldn't worry about it.
EDIT: If you're going to be gaming, don't get anything less than a 5700 Ultra, but I'd recommend a 5900nu or higher.
Jojo1971
2,200
newer shuttles come with 250W PSU...look at my sig...im using all the components that you see in it..i think one of the most important thing you have to concentrate on is GOOD COOLING/ VENTILATION especially when using "furnace-like " components such as high-end video cards and 2 HDDs.. adding a top blowhole will help alot..
blowhole mod here..
edro
24,326
68
I have an SK41G (200W PSU), with the following inside:
AMD 1900+
120gb WD 7200rpm
80gb Maxtor 7200rpm
Radeon 9700 Pro AIW
DVD-Burner
Neon Light
It all works flawlessly.
suklee
10
My Shuttle (see sig) runs @220 x 10. It's on a 200W PS and runs 24/7 without problems. CPU temp never goes above 50.
