It has been oos for weeks now. Does anyone have any info on this? Did they just simply run out or is there a defect that caused them to be pulled from vendor shelves? It practically happened overnight.
850HX was the first of the HX series if I recall. They are probably getting ready to roll out a new revision/series and it makes sense to replace the oldest model first.
