One video feed, the rest are data and charts from scopes.are you displaying lots of different video feeds at once? you'll need something different if that's the case
I'll be doing a screen capture of the monitors.
I thought two cards in SLI or CF should be able to do that.
Can monitors be connected to both cards?
Not all of our monitors are DP that's the reason I am checking if SLI/CF might work.
Another crazy idea might be to create a virtual desktop with 6 monitor resolution if that would be possible.
The screen capture assures the time synced data; it will be post processed and trans-coded after.
Thanks for the tips.
Actually, it's going to be a video screen capture using NCH Debut software.if you wanted multiple video feeds (e.g. TMC operator), an active virtual monitor that gets split after the video card would be the way to go.
otherwise, no worries, printscreen still works with multiple monitors.
