The best case for quiet operation?
Ichigo
2,158
But anything else that costs the same or LESS?
Don't have Lian-Li here in Canada nor will I pay the horrendous shipping fees, so don't bother.
Ichigo
2,158
Richmond Hill, a small suburb near Toronto. Best place here is a Canada Computers. Service isn't great, but the prices are usually pretty good. No Lian-Li though.
Howard
47,982
11
Try Infonec. They have the SLK3000B. Might not be as quiet as the P180, but certainly much cheaper and can still be made pretty quiet.
Bobthelost
4,360
Well the P150 is better out of the box for really low noise.
Otherwise a bit of modding to a Sonata II will get more or less the same result.
potato28
8,964
Dude! BIGFOOT!!Theyre right on the other side of Toronto... and they carry Lian-Li!
RKS
Originally posted by: RallyMaster
Pretty much any case that uses 120 mm will be quiet with the proper fans.
combine it with a good fan controller and a better HSF and you are all set.
Ichigo
2,158
Yeah just realized that I don't want to spend over $300CDN for a Lian-Li. I'm probably going to stick a Conroe setup in a P180 when I get the cash.
Fallengod
5,908
19
P180 is a good case, despite what people might complain about. :) You should be happy with it.
One43637
221
if you don't want to shell out the cash for a P180.
