That LED Christmas light flicker
Discussion in 'Off Topic' started by reitz, Dec 10, 2010.
  1. rockyct
    rockyct Diamond Member
    Jun 23, 2001
    6,658
    32
    No, I haven't but you sure are tempting me now. ;) Actually, it should take far less than 120 volts to see if it works. Maybe only around 40 volts or so. The threshold voltage of the LEDs is pretty low. Hmm...I'm going to go see how many 9V batteries I can scrounge together.
  2. Rubycon
    Rubycon Madame President
    Aug 10, 2005
    17,771
    481
    Yes you are correct - I'm so used to "firing voltage" of NE2 lamps of 85+ volts. The LEDs will glow - albeit dimly - but you should see interleaving if that's the case.
  3. Leros
    Leros Lifer
    Jul 11, 2004
    21,873
    I built a full wave rectifier for my set of lights. They were all turned on with that. However these were short 40 bulb strands I bought at the grocery store, not long enough to justify putting bulbs both directions.
  4. bobdole369
    bobdole369 Diamond Member
    Dec 15, 2004
    4,504
    Vforwards gotta be at least 0.6v on LED's right? So 100 lights * 0.6v = 60v just in bias voltage. Theres gotta be a ballast somewhere.
  5. Rubycon
    Aug 10, 2005
    17,771
    481
    Cockroft-Walton multiplication?
    I know white LEDs can need more than 2V. :eek:
