thanks for the help guys!
David101
hey guys. i wanna thank you guys for the help in purchasing my new comp 😀. i got a:
2500+
9500 np
512ddr333
k7n2-l
i put it together myself-so i have a few questions lol.
i need to know what temp my system should be running at. its 26-33 idle and 42 max load. i thoguht it would be higher...maybe its normal (stock heatsink) but i need to know if something is messsed or thats normal 🙂.
and oh btw-i touched the thermal pad so i dont think that would be bad would it...lol
and 1 more thing-all my front panel stuff (hdd led and stuff) is connected wrong lol. will that mess anything up, or just not work?
thanks,
David.
Sounds like you have a good case setup and the fan is on properly, good work.
Not a problem, though having the reset button hooked up might be useful eventually. No hurry if you are using XP/2000 instead of 98/ME.
