Thanks for help Final thoughts
jpinks
54
Thanks for all the help on the power supply I thought that was totally nuts that this system would need a 900w supply!
MSI P67A-GD65 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Model #:p67A-GD65 (B3)
Item #:N82E16813130574
Return Policy:Standard Return Policy
Update14-150-517 XFX HD-697A-CNFC Radeon HD 6970 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Model #:HD-697A-CNFC
Item #:N82E16814150517
Return Policy:VGA Standard Return Policy
In Stock
Update17-139-006 CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power ...
Model #:CMPSU-750TX
Item #:N82E16817139006
In Stock
Mail in Rebate Card17-139-006
Update19-115-070 Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
Model #:BX80623I72600K
Item #:N82E16819115070
Return Policy:CPU Replacement Only Return Policy
In Stock
Update20-148-348 Crucial RealSSD C300 CTFDDAC128MAG-1G1 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
Model #:CTFDDAC128MAG-1G1
Item #:N82E16820148348
Return Policy:Limited Replacement Only Return Policy
In Stock
Update20-231-314 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
Model #:F3-12800CL9D-8GBRL
Item #:N82E16820231314
Return Policy:Memory Standard Return Policy
In Stock
Note (Add20-231-314)
Update22-152-185 SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:HD103SJ
Item #:N82E16822152185
In Stock
Note (Add22-152-185)
Update27-135-204 ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Model #:DRW-24B1ST/BLK/B/AS
Item #:N82E16827135204
In Stock
Update32-116-754 Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
Model #:GFC-00599
Item #:N82E16832116754
Return Policy:Software Standard Return Policy
In Stock
Update35-103-065 COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel ...
Model #:RR-B10-212P-G1
Item #:N82E16835103065
In Stock
Subtotal: $1,556.90
Order going out on Monday, anything I might have missed please let me know, and thanks again.
mfenn
22,400
www.mfenn.com
See my post in your other thread. In the future, please try to keep it to one thread per build, otherwise it gets really annoying having to cross-post everywhere.
Nov 26, 2005
15,197
403
Yeah, if you just hit the "Edit" key at the bottom of any of your posts you can edit it...
EDIT: in stead of making a new thread
