Okay my problem lies in the fact that whenever I select FIX in the bios to set my AGP and PCI @ default speeds my pc won't boot up. It just goes nutz beeping. Now here is the totaly weird part , if I don't use the Fix or the 2/4 option but use the 2/3 the default one my pc will work without any problems and it will boot up etc. I'm runing a p4 1.8Ghz @ 2ghz using 111mhz fsb. So it sets my PCI @ 37 and my AGP @ 74mhz if I use 2/3. Well I want my AGP and PCI @ there defaults. Anyway the fix option will only work if I first select the 2/3 then save and exit then come back again and pick fix. This will let my pc work and go into Windows. Now where my other problem lies is that if I'm using the Fix option and shutdown and then try to power my PC up again it won't boot!!! It just beeps like crazy and gives the error code AE or AF which I can't even find on the Abit manual to see whats up. Anyway it boots up if I use 2/3 but not if I use 2/4 and Fix. So anyone have a solution?
