Hi,
I'm looking into buying a good TFT monitor for all day working. We are talking Windows, Word, Excel.
I've been looking into Samsung SyncMaster TFT 730BF, it seems to be a nice looking monitor for about 340?.
Now looking into his specs, I read (don't understand much about tft monitor specs):
----- Panel
Type: a-si TFT/PVA
Viewable Area: 17"
Pixel Pitch(mm): 0.264
Brightness (cd/m²): 300
Contrast Ratio: 600:1
Viewing Angle(H/V): 160/60 degrees (CR > 5)
Interface: Analog/Digital
Response Time (ms): 4 (Gray-to-Gray)
----- Frequency
Horizontal Frequency: 30-81 kHz
Vertical Frequency: 56-75 Hz
Bandwidth (MHz): 140
Maximum Resolution: 1280x1024
----- Colour Supported
Maximum: 16.2M
Now I have some questions:
1. Your opinion, is this a good solution to work? And for some gamming? (if it's good, I'll may end buying a second one for home usage)
2. How can I "read" the specs and understanding them? I mean for example, a contrast 600:1 is good? better or worse than a 400:1? Why?
3. This only have a 4ms speed? Is this possible at this price, or is there a catch? Although it's a 17" monitor, I wouldn't believe I could get a sub-8ms for this price.
4. If tft monitor speed is measured on response time (4ms in this case), why do they show some horizontal/vertical refresh? That's the regular "speed" measure for CRT monitors, is this just for compare? Because if it is, then it will be well bellow a CRT specs, although I know CRT are still better than many tft monitors.
5. When looking for eye-care, what specs are important in a non CRT monitor?
Thanks for the answers, I'l looking forward to understand a bit more about this monitor techs.
----- Panel
Type: a-si TFT/PVA
Viewable Area: 17"
----- Frequency
Maximum: 16.2M
