TFT/LCD display using VGA (Acer X193WB)
Turbonium
2,157
82
I may be getting my hands on an Acer X193WB at a very good price, but I'm having some last minute doubts. Should I be expecting noticeably poorer IQ (baseline quality, colour accuracy, ghosting) due to it being VGA as opposed to DVI?
The monitor will be connected to a 6800 GT, built by EVGA. I have no clue as to the quality of its RAMDAC, which as I understand it, is an important factor in determining the IQ.
Andrew1990
Banned
Mar 8, 2008
2,153
Ah, I got the X193WB+ with a 1680x1050 resolution. Most of the time I use the DVI port but I was forced to use the VGA port for two weeks because of VGA replacement. The DVI in my opinion shows some improvement over VGA but nothing big.
I did have a problem where the screen was off the monitor a tad but I think that is because I was using an ultra old Radeon 7000 PCI.
Turbonium
2,157
82
Define "improvement". You gotta give me something tangible here.
Are we talking better colours? Less ghosting? What?
nitromullet
9,031
36
Better colors and clearer/crisper picture with DVI. I don't think ghosting will be affected. I run two Dell 2007FP screens side-by-side at work, and one is on DVI the other on VGA. You can definitely tell the difference.
Personally, I'd be suspect of an LCD that doesn't have a DVI in the first place. These screens are usually very low end.
Turbonium
2,157
82
I would rather DVI as well, but I'm getting this monitor for less than half what it normally costs. My desktop (see sig below) needs a monitor! And I'm on a budget, so this fits the bill methinks.
Zap
22,377
7
Most Acer monitors have an "auto" button that will re-adjust the screen when using the VGA input.
I think part of it also depends on the monitor and the quality of the portions dealing with the VGA input. I had a CTX 17" LCD with VGA and DVI, and the VGA input on it was really crappy because you can easily see the difference. However, I also had a 19" Acer with VGA only, and it was easily as good, if not a hair better than the CTX using DVI.
Turbonium, unless you do side-by-side comparisons, I don't think you'll notice a huge difference.
Andrew1990
Banned
Mar 8, 2008
2,153
The picture seems a little crisper to me but that is about it.
brblx
5,499
DVI generally sharpens everything a bit and makes text a little better.
as others have said, it depends on the quality of the analog input. my first LCD was a samsung that had great VGA quality. my current gateway does not.
Turbonium
2,157
82
Here's to hoping it has a good VGA input.
But I guess at 70USD, I can't really go wrong.
