Testing Power Supply Rails-
tufkal
4
So I have a reallly wierd PC im trying to fix, where the DVD-ROM and HD both died at the same time, but everything else seems fine. I have a new power supply to replace the old one, but im not convinced it was his PS. I have a multimeter and according to the mutlimeter, and the bios readout, all volt rails are within range.
What I want to test is the draw on those rails, as related to the amps lsited on the side of the power supply. I know very little about using a multimeter to test anything except volts and I dont want to damage the PS if it is indeed functioning properly.
Can anyone tell me what settings I should have the multimeter set at and where to poke the cords to get the readings I am looking for?
oneshot47
435
Most mm's that ive seen cant handle the amount of amps a typical psu puts out. Youll have to spend a bit more money for that.
Geniere
336
Yeah ? All of the DVMs I?ve used only allow current measurements up to 10amps. You can use three DVMs in parallel to read up to 30amps or 5 for fifty amps if you have access to several meters. Just total the readings.
If the rails have the proper voltage, your probably ok if the readings were taken when a particular rail was near full load, i.e. HD?s were writing continuous data.
Use an ?O?scope or switch the DVM to AC volts (low volt position) to measure and/or look at the ripple voltage.
beer
11,169
Yea uh...I wouldn't recommend that. If one of your contact leads slip you have a bunch of very dead multimeters. (at least until you can fix the fuse)
damonpip
635
Most multimeters only will test up to 10 or 20 amps. Even if you parallel several multimeters, you will have trouble getting a useful reading because the multimeter will only measure the current draw at that point in time, not the maximum current output of the power supply.
Geniere
336
Indeed, thats why I added:
"If the rails have the proper voltage, your probably ok if the readings were taken when a particular rail was near full load..."
DungeonMaster
OMG!!!!!!!!! You NEVER Connect a Multimeter directly to the source to read the max current. The use o the Amp function is to put it in serial with the load (motherborad or a resistor) and then see the current. Thats because a multimeter in amp mode has ) Ohms resistance and the current that is going through the MM is theoreticaly not countable. The mathematical explanation is...
I (Amps)=V (Voltage) / R (Resistance) <=>
I = 12Volt / 0Ohms = Countless. Do it in the windows calculator. By using a mm in that way you burn its inside fuse and you put a great stress on the PSU.
xenos500
354
Testing your powersupply by shorting it out with a meter would be like testing a smoke alarm by setting your wall on fire.
14,090
You need to to "add" it in the circuit, in series... at least that's how I do it to test household amperage, but I was later told if it's not true RMS it's not accurate but for DC RMS is not an issue.
So it would go yellow wire -> multi meter ->load (ex: hard drives etc) -> black wire.
But like what has been mentioned most have a 10 amp limit. Though I'm not sure if this limit applies to low voltages such as 12 volts, since I think the limit is mostly heat related, a 120v circuit that is drawing 15 amps will heat up small wires, but a 12 volt circuit drawing 100's of amps won't. So small components inside such as the fuse won't melt. Though I would not take a chance anyway since I'm probably wrong, there must be other factors related to the limit.
Geniere
336
Some posters obviously have poor reading skills. I earned a 6-digit income because of my knowledge of electronics and used that knowledge in the proper application of test instrumentation. One certainly can insert a parallel group of ammeters in series within a circuit. My previous post is exactly correct.
PlasmaBomb
11,636
A fuse is melted (fused) by the current going through it not the voltage of the system. Thats why they are 1A,3A,5A fuses etc. not 1V...120V fuses.
beer
11,169
For a highly technical forum, the lack of knowledge here seems a tad scary
