testing input lag with a mouse!
Katys
I did some googling about monitors input lag and found 2 methods. One needs a CRT monitor and a high speed camera, the other is buying a lag tester which costs 100 dollars.
However I was thinking about using a mouse to do it!
Did some more googling and found this: http://www.draebenstedt.de/reaction/loopback.html
The author did the program to test reaction times, but he noticed a discrepancy between PCs, so he did a test mode to define input lag.
You need a optical mouse, lasers don't work for some reason
Tape the red light, since you need the mouse to detect movement on the monitor. Also keep it 3 mms from the screen, something about focus.
I'm on my cel atm, will test it when I get home.
It's not a bad idea, this way we can even test wired and wireless mouse input lag.
These guys tested the program: http://www.teamfortress.tv/8976/program-that-estimates-input-lag
Post results.
