Testing home built PCs
piotrgurin
343
I did mem test on all of them for 20+ Hours, RMAed defected RAM.
What other tests do you guys recommend I run b4 i pack em up for shipping?
Thanks,
-Pete
OdiN
Banned
Mar 1, 2000
16,430
Prime95 and some sort of video test for a few hours. Also Prime95 them in less than ideal conditions if posible...IE in a closed-off desk or somewhere where it can't get a lot of air because you just know that's how they will end up.
I always zip-tie up any loose wiring and make it a nice clean install.
imported_rod
1,788
Prime95.
Also, if they're all the same, run PCMark or superPi something like that, and if one computer has a score significantly lower than the others, you'll know it has a problem.
RoD
piotrgurin
343
Yea there probably going to go into a cabinet. Thats why i went with AMD to keep the heat down.
Good ideas on the tests, thx.
