- Jul 18, 2009
- 122
- 0
- 0
I have an Antec EarthWatts 650 which I picked up a few weeks ago. The first system I used it in, I had a new video card plugged into the molex connectors (via a PCI-E to molex converter that came with the card). That video card died (total electrical failure) after about a week.
I had other problems with that system, and it was getting near the end of its lifespan anyway, so I spent money on all new components when I replaced the video card. I re-used the same power supply as before.
The case I bought came with front-mounted fan controllers. When I set everything up and powered on, the system worked for a few minutes and then one of the fan controllers exploded (popped/sparked/smoked).
I've been testing the power supply since then. I have it sitting out on a table, with a paperclip connecting green and black pins on the ATX connector. I only have a crappy analog multimeter, but with no load at all, the voltages are stable and within spec on all circuits and rails. The power supply appears to be fully functional, in spite of withstanding two catastrophic electrical failures on the same molex circuit.
I'm still a bit leery of this PSU. Is there anything else I can do to test it before putting it into my new system, or I am just being paranoid at this point?
