Testing a power supply?
4fingerwu1
405
Is it possible to test your power supply to ensure that it is completely functional?
How would one go about doing this ?
Thank You
Ric
tcG
1,202
18
Connect POWER (usually green) to GROUND (usually black) on your 24/20 power connector... I use a paperclip. Make sure it's plugged in, and it should turn on.
DaveSimmons
40,730
670
Antec and others sell cheap basic PSU testers starting at around $15 that put a load on the PSU. I use one of these on each new PSU for about a minute to make sure it's not EOA (exploding on arrival :) ).
Look at the SilentPCReview.com PSU reviews for mentions of higher-end test equipment that isn't worth buying unless you want to review PSUs :)
Your motherboard BIOS and monitor software can tell you about voltages
