I think those testers just measure the open (unloaded voltage). If I need to test a supply I plug it into a few bad (but still spinning) hard drives I got laying around to give it some load and measure with a multimeter. I also check the power OK line, sometimes the supply will appear to work but not output a power OK signal.
