I'm looking at a Dell XPS 400 that has a 375W power supply. The computer is a BTX form factor system, so I'd assume the power supply is BTX as well. It has the same 24-pin ATX and 4-pin 12V connectors as an ATX power supply.
My question is should my ATX power supply tester be able to test it? From what I've seen in ATX & BTX specs, the pinouts on the power supply connectors are identical. When I plugged in the 24-pin connector, all of the voltage levels checked out as normal by the tester. When I plugged in the 4-pin 12V connector it caused the tester to not even function, so I'm thinking the problem with this system is the power supply.
