Tessellation in BF3
Like I said AMD optimized doesn't override the tessellation factor in EVERY game. Only games where AMD decides a higher than optimal tessellation factor is used by the application. AMD optimized have no effect on 3Dmark11 score or Heaven 2.5 score. And it certainly doesn't turn off all tessellation and give you no performance drop.
http://www.nordichardware.com/news/...t-catalyst-112-with-tessellation-control.html
AMD optimized is the default selection in CCC. Why would they help code in DX11 in BF3 then force tessellation off with AMD optimized? It makes no sense.
AMD optimized only works when AMD have a profile in place.
But AMD "optimized" still means it overrides what the developer wants...due to AMD tessellation deficit.
In this interview, Dice confirms tessellation in the game.
http://www.youtube.com/watch?v=wVDmRHJzlvo
Operation firestorm MP looks to be the perfect candidate for distant terrain tessellation.
Terrain medium
Terrain ultra
CCC tessellation off
CCC tessellation application controlled
I still dont see any IQ or performance drop from tessellation on.
Hawx 2 tessellation comparison
It sure does look a whole lot better with tessellation though it cut the 5870 fps in half!
http://www.tomshardware.com/reviews/geforce-gtx-570-gf110-performance,2806-4.html
Overall pretty disappointed with the lack of tessellation in BF3. I can only imagine how much better it looks if it uses tessellation the same way as Hawx 2
Edit UPDATE: OK I have finally pin down where the tessellation was actually applied. Its there all along on the distant mountains. I made the mistake off changing CCC settings with Afterburner running before. It worked now.
Tessellation off
Tessellation on
It looks like the tessellation in BF3 is pretty well optimized too. Only a 10% drop on a 5850 on a scene with nothing but mountains. It should be even less of an impact in more demanding areas.
They added the extra shaders to handle tessellation but clearly they didnt add enough. On previous cards it was done with the vertex shaders
Terrain medium
Terrain ultra
Tessellation off
Tessellation on
It's good to see some tessellation but personally can't wait for much, much, more as hardware improves from AMD and nVidia. Thanks, for taking the time!
Sense...you make none.
AMD's(ATi's) previous tesselation was nothing like the tesselation in DX11
http://www.anandtech.com/show/773
This time around AMD made a fixed tesselation engine in the 5xxx series...and added one more (for a total of two) tessellation engine to the 6xx series.
NVIDIA made a unified approach using thier shaders, hence why their implementation has superior performance.
I think he meant the tessellation unit on the HD2000-4000 series and the 360...Not that I know what's different though😀
It's hard to complain when BF3 looks as good as it does.
Exactly. The game is better looking than Crysis 2, so who cares. It also performs better. Shame on Crytek.
The game is a testament to how worthless anything we have seen done in DX11 with tessellation is as yet.
BF3 making minimal and moderated use of tessellation is still the best looking DX11 game around.
It's debatable. Overall I would give BF3 the edge as it performs better.
My issue with Crysis 2's tessellation is that it was overdone. The bricks actually look pretty ugly with it turned on, and it can be a performance hog if there's too much tessellation going on at once. It's obvious that it was an after thought, whereas in BF3 they actually used it well and optimized for it.
This i agree. It seems much more efficient than in crysis.
Can some test the performance drop on the 6900 series card?
Turn it on and off in CCC and see the performance drop.
can do...give me a few minutes to run a benchmark
edit: a few benchmarks I ran using Crysis 2 and the Adrenaline benchmark app. I ran the central park benchmark as it has a lot of brick and rock structures that use tessellation in varying degrees and it's a repeatable test. Everything was run on Ultra in DX11 using the high resolution textures, 1920x1200, 0x AA, 16x AF. I changed the Tessellation setting inside CCC.
No Tessellation: Min 12.4fps average 42.4fps
AMD Optimized: Min 7.7fps average 28.5fps
Application controlled: Min 7.7fps average 28.5fps
8x Tesellation (used the slider in CCC): Min 9.7fps average 36.7
So this tells me either AMD optimized doesn't work or there is no Crysis 2 profile so it defaults to whatever the game uses. The slider works to control the tessellation level and to my eyes I could not notice a huge difference in quality, but the fps was better. The minimums were severely below the level you'd like to have by any stretch, but the averages were 8fps higher which is pretty good. No tessellation still looks good but there is a noticeable depth difference in brick surfaces and some rock structures. However, the FPS is still too low at my standard resolution to give a good experience if you judge the minimums as a basis for playability. I could not tell how long the fps dropped to this level, it is possible the timedemo started recording and read low fps prior to a fully loaded level, I do not know for certain. However, below 30fps average is substantially lower than I could play the game.
In Battlefield 3 There was no way to make a 100% repeatable test as I have not found any benchmark apps for the game. So I ran everything on ultra, MSAA off, blur on and slider set to the middle. 1920x1200 16x AF and ran a few times through Operation Guillotine's first few minutes with fraps benchmark. This mission in single player won't tell you how MP will perform but it seems to have some usage of tessellation with the terraign and rocks, walls, and structures etc. Also realize with this method there is a margin of error as it's impossible to do everything exactly 100% the same each time, but I did my best to repeat it.
No Tessellation: Min 45fps, max 82fps, Avg 62.58fps
Tessellation 8x slider in CCC: Min 42fps, Max 86fps, Avg 61.79fps
AMD Optimized: Min 39fps, Max 85fps, Avg 58.8fps
Application Controlled: Min 33fps, Max 82fps, Avg 55.91Fps
So I'm going to say that between no tessellation and using 8x, there is almost no difference whatsoever in the performance. I don't know what AMD Optimized is setting it to but there is clearly a profile in the drivers or CAP, but it's set lower than Application Controlled (64x?) and higher than 8x, or perhaps there was some dynamic tessellation rendering going on where things were adjusted on the fly but I don't know how it works so I could not say. There was almost zero visual difference as I believe there isn't much tessellation at all in the engine. There's definitely some because as you turn it down the game gets higher fps, but I don't think anyone should just turn it off here. 8x seems to be the sweet spot generally. It's only a few fps difference, but it's something.
Great. Minimal performance drop on a 6950 as well. Operation guillotine being a night map, I don't think you can see that much tessellation effects. The best is Thunder Run or Operation Firestorm MP.
Thats very debateable. Crysis 2 is a much better looking game than BF3, and not only does it use more DX11 features, the effects of DX11 are much more noticeable.
No.
Get into a 64MP map like caspian (fly a jet or just infantry in the forest), dpeak(outside high or inside the tunnel), or even tehran and you will see the amazing lighting & shadow system in frost bite 2. It makes the game look amazing on another level.
Crysis 2 with the texture pack makes objects look good, but BF3's lighting makes the entire scene look amazing.
No.
Are we going to start a screenshot war? Because I'm ready to go 😎
BF3 looks great don't get me wrong, and the map sizes are incredible. But Crysis 2 with DX11 Ultra looks flat out amazing!
Crysis 2 has SSDO (superior to HBAO), real time local reflections, variable penumbra, water physcs, extensive use of tessellation etc which just bring the game to a whole other level visually.
The only thing I don't like about Crysis 2 was that some of the textures were too low grade, even with the HD texture pack. But there are texture mods out there that rectify that problem completely, so now the game looks damn near perfect.
Both engines, cryengine 3 & frostbite 2 are state of the art, real art in games is a whole different matter.
There's more rocks and things all over the first 2 minutes of guillotine than any other map. If they were to use tessellation, it'd be there.
Just not seeing it at all with Crysis 2. BF3 is the better looking game. Crysis 2 may have all sorts of effects going on, but when I look at what was presented on my screen, BF3 is the superior game for graphics. We won't even touch gameplay, BF3 is leagues ahead of C2 there.
In BF3 on a map like Grand Bazaar or the single player campaign; those urban settings blow away anything I saw in Crysis 2 and C2 was nothing but urban stuff.
I think too many concessions were made for consoles with Crysis 2, it certainly felt like a console port whereas BF3 does not. I also think Crysis 2 is hard to like when the four year old original looks better than the sequel :thumbsdown:
You're referring to art it seems, and not graphics. Art is subjective, but graphics isn't. Crysis 2 is quantifiably superior to BF3 graphically, and you can show this by looking at the technology both games use, as well as screenshots:
In each of these screenshots, you can see clear use of the various graphical technologies used in Crysis 2 DX11, such as SSDO, variable penumbra, tessellation, parallax occlusion mapping, real time local reflections etc..
I challenge you to show me anything in BF3 that looks anywhere near as good as those screenshots......especially the last one showing a great view of the Cathedral.
Initially this was the case, but the DX11 and hi rez pack changed that.
Both have their own short comings. Crysis is very inefficient in its tessellation. Turn off HBAO and you can see the indoor lighting in BF3 is quite flat. Metro2033 beats them both I would say.
So is tesselation on by default in the ATI drivers? I have mine set to AMD optimized.
Or do I have to uncheck that and set the slider to 64x?
