Terrible FPS in Tribes 2 w/ Radeon, Need Help....
FSB
72
System
Radeon 64MB DDR. -overclocked to 185.
T-Bird 900Mhz
128 MB ram
I am getting on average about 10-30 fps outdoors and 30-60 indoors...
I have downloaded Raid-On Tweaker and tried each one of the different profiles but none of them give me good fps at all...
Does anyone have any ideas of what could possibly gain me some fps...Or maybe could create or know's of a profile for tribes 2... Or possibly knows of a better tweaker...
Please post any ideas, all are much appreciated.
HELP! :(
arod
4,236
First off Uninstall all of those tweakers except for powerstrip. Then use it to enable Hyper Z and over clock your card. Also install the latest drivers from ATI special purpose drivers
In tribes 2
my res is at 1024x786 32 bit color
all textures 3/4 way up
sky is totally off (no sky)
no shadow detail
32 bit textures and all about 3/4 up
This is how I have mine and with my Tbird 1000 I get 50-100 FPS depending on whats onm the map. Hope this helps...
Dec 28, 2000
195
Hmmm strange?
sorry can't help but here is a tip
if you installed a new Vid card and Tribes 2 was on your HDD before you installed the new Vid then you should reinstall Tribes...
reason
Registary problems
sometimes Tribes 2 is using the old Reg for the old Vid you had
This happens with Diablo 2
Davegod75
5,320
when I installed the new 3132 drivers for w2k my fps went way way down for tribes2
