- Jun 30, 2004
- 16,878
- 2,190
- 126
UPDATING THIS INITIAL POST:
If you read my "Call to Arms" thread, you will have to concede that there was some sort of problem with SLI configurations of GTX 9x0 cards -- that I wasn't the only person who noticed it. I can't say whether the others "figured it out," but I did, after putting in an NVidia support ticket. I stumbled onto the solution before receiving any sort of guidance from NVidia.
The "fixes" in this initial post here were not the real McCoy, and only led me to more drastic measures. Those follow through the length of the thread as of March 12.
My request with this thread arises because I can't understand how my problem solution worked.
The solution to the higher-than-normal power consumption and idle clock speeds was to simply select the AfterBurner checkbox that makes it load at Windows startup, putting its little fighter-plane icon in the system tray.
I needed Afterburner to implement custom fan-control to my satisfaction, and when I deselected "Apply OC settings at startup," fan control would revert to the default -- with the fans not running until temperatures reached 50 or 60C -- maybe higher.
Solving the power consumption problem only required making AfterBurner load at startup. Of course, this means that my SLI graphics configuration is joined at the hip to a piece of software -- never mind the software was bundled with the GTX 970s.
So I'm wondering how Afterburner manages graphics card settings -- including OC choices. Does it save some sort of "profile" to be loaded at startup? Does it make changes to the cards' BIOS'? Why is fan-control dependent on "Apply OC settings at startup," when the Ai Suite fan-control for my motherboard remains implemented at the BIOS level, and I don't need to run AI Suite to keep the fan settings?
Maybe someone knows. I've done some web-searches today, and all I find are guides and instructions for using Afterburner, but no explanation of how and why I need it running at startup.
