I've had this 6800gt for a while now, probably close to a year, and I was previously using it with a 21inch CRT. It would get pretty hot while playing games, enough to pop up that temp notification saying it'd got as high as 120C. I ended up just opening the side of my case and sticking a big 12 inch fan next to it and that did the trick. Messy, but I really dont care.
The other day though, I got a Dell 2405FPW and running games at 1920x1200 is KILLING this card. I can have the fan on next to the card and it still will overheat like crazy. Right now I dont have that 12 inch fan going, but the ambient temp is 50C and the GPU core temp is 82C, just posting crap on the internet.
Is this normal? Is there anything I can do about it? Any aftermarket heatsink/fans you'd reccomend?
