- Jan 16, 2001
- 31,528
- 3
- 76
I don't get it. Higher fan rpm = better airflow = lower temps. That's the way it's always worked...now it doesn't.
I have an Antec 1040. Aside from the dual-fan PSU, I have two exhaust fans and one intake fan.
I have the fans all hooked up to the "Fan Only" speed controlled connectors on the Antec Trupower 430 PS. The fans are basically 7-volted. The spin very slowly, but move air. You can feel air being sucked in thru the front grill when you put your hand there. You can feel the air coming out of all three exhausts. (PSU and case fans)
I felt my case temps were a little high, so I decided to take my fans off the speed control and run them straight...much more noise, but lower temps.
Well, the noise went up and so did the airflow. You could REALLY feel air coming/going on both ends...but my temps didn't drop. Not a single degree C!
Neither the CPU OR the CASE temp.
What happened here? Was it just hot in my room that day?
Right now, room is 76F. Case temp is 102F. CPU is 113F. I have zero stability probs. I have a big CPU HS which radiates massive heat, along with my overclocked 9800, which is also a space heater. Any ideas? Should I try it again?
